OBD II Power Output/Constraints
4SUPER9
2022 Model S
Jun 6, 2013
3,572
3,581
So Cal
I have my new MS on order and preparing for all the mods I will be performing, likely on the first free day I have available. Two (of the many) additions I will make will be a dashcam (Blackvue) and a radar detector (Escort 9500 or similar).
My preference for the dashcam will be to obtain power from the mic grill in the headliner. That is, if my vin has the connection piece that so many others have found (it was not in my prior vin 15xxx).
I was thinking of getting power for the radar detector from the OBD II connector, instead of routing from a tap-a-fuse. Tapping from the fuse is easy enough, but I will have to match a notch in the fuse cover in order to get the wire out, and being a leased vehicle, I would like to cause as minimal damage to the vehicle as possible.
My questions are as follows: will the OBD II connector have sufficient power for my radar detector? If so, and I cannot find the power access behind the grill, might it have sufficient power for BOTH the radar and dashcam?
Thanks!
I bought a hd dash cam on line for $65 mounted it to the right of the mirror routed the wire under the headliner to the pass pillar down to the floor under the passenger seat and to the 12v power plug as for the radar dec. just don't go that fast, it just tells you when you are going to get a ticket and it wont keep you alive. (sorry I know keep your though to your self.) you could put a splitter there and plug both in with no wiring to mess with.
I was just thinking as to why a tesla would even have a OBD II port? Isnt that only for monitoring ICE car information?
It's required by law and the laws have not yet been modified for EVs.
The OPD2 12v output is more than hefty enough to power these kinds of devices. I used to to power the front/rear camera switch. And it's always on which is a good thing for a dash cam.
I used a fuse tap for my Valentine One, which I sealed and mounted behind the nose cone due to the metallic windscreen. I had no problem gently closing the cover over the standard-issue fused cable. I just went slow. Been fine for 16 months. Might be worth a try. Also, are you buying new? I expect you will have the vacant connector in the mic area. I did with my VIN, below.
Yes, I am buying new. I heard that there was a gap where the connector was not present. I find that so odd. They had it for about a year, then it disappeared for a year, then it came back. It must have a purpose. Some people have speculated that it was for lighted visors.
With my last radar, Escort 8500 Plus, I used a tap-a-fuse. I absolutely could not get the cover to close over the wire. When my new car arrives, I can try again. Using the OBD II though would be so easy.
