Tesla Model S X Obeche wood Dash vent Trim Passenger side bezel | eBay
If you have a mint or damaged Obeche horizontal passenger panel to
hat needs replacing and plan on using a phone/tablet mount for your Tesla, this is the item for you. Don't mount anything to your current dash trim. Buy this item instead so that you can install a permanent mount solution that will allow you to restore the original finish before selling the car.
Tesla Model S X wood Dash vent Trim bezel Set Finisher Panel OEM. Condition is Used. Obeche open poor horizontal grain. Small chip the can be repaired using wood filler kit. Came from a 2015 P85D Model S. No broken tabs or other plastic damage.
Replacement for Tesla OEM part 1004518-06-F INSTRUMENT PANEL FINISHER ASSEMBLY - COMPLETE SET WOOD OPEN PORE - HORIZONTAL. The item for sale is only 1 of 3 components (the passenger side fitting) of the set.
The defect is approximately 2.5 cm wide, 0.8 cm long, and 1 mm deep. There are 3 horizontal groves within the defect go deep to the laminate underneath the wood fascia.
