Yes it is cool, but I wish the notice was pushed to my phone instead of just appearing on the car screen or hidden on the app - still it is nice that they tried
Did you check the Tesla app? I got the message last night a little after 9pm.
I’ve started a new thread in the California Supercharger forum where you can post if you have verified or reliable information that a Supercharger is not operational because of a utility power shutdown, seeThe Napa supercharger is offline but the Vallejo one, 10 miles further south is operational.
PG&E's web servers are getting hammered. There is some info on their twitter feed: PG&E (@PGE4Me) | Twitter
Also, this:
PG&E @PGE4Me 7h7 hours ago
#PSPS Zip Code Alerts: To enroll call 1-877-9000-PGE. Alerts will be delivered via automated call. To sign up for text alerts, text "ENROLL" to 97633: http://bit.ly/2IyTYUm
MASTER THREAD: post here if you know that a Supercharger is down due to utility power shutdowns
@ChrisJ did you visit the Napa Supercharger today and found out it is not operational, or did you hear that from someone?
You mean be lame?fwiw: we've had mandated blackouts for fire prevention in SoCal for years. NorCal is just starting to get with the program.
The upside of course, is that SoCal is semi-arid so many trees grow large; in contrast, rainy NorCal has a LOT more growth & forests to trim back.
I just received a notice on my car about PG&E potentially shutting off power. Tesla suggests charging to 100%
It looks like our address will be unaffected, but the planned outage map is drawn with big jagged angles and has a section pointing up across 280 into Sunnyvale, so it's anyone's guess where the actual shutoff boundary will occur. Like you said: really not sure what we can expect here.
The car is plugged in and will reach 90% before midnight. Also have portable lithium-ion jump start batteries ready in case we need to charge our phones. Made some extra ice packs in the freezer. Water bottles are filled.
Hopefully this manufactured emergency ends up being just a lot of hot air. Good luck tomorrow, everyone!
Not all homeowners may be able to install a large generator, but also not all homeowners can install PV and battery either. Also, new CA building codes in effect and going into effect 2020 will make it a harder to install battery backups.
I think you know, but just to clarify in case others get the wrong idea, solar is required only for new residential builds. And it’s not even a requirement for the panels to be on the roof. As long as some of the energy pulled into the home comes from solar, regardless of whether it’s from an HOA community solar farm, or a solar farm 100 miles away, it meets requirement.
Regarding the building code for batteries, interpretation of the new code shows installing one battery on the wall is fine.
But, with more than one battery installed inside, there has to be at least 3 feet separation from each battery, walls of the garage/home, and other equipment. There goes that second car space in the garage. 4-inch diameter steel bollards, no less than 3 feet tall, to protect against vehicle impact.
Exterior placements require it to be on a pedestal, and minimum 5 feet from lot lines and public ways. 10 feet minimum from any means of egress from a nearby building. Must be secured from unauthorized access such as with fencing all around.
But, it’s said that some of these requirements can be exempt by local jurisdiction. So, nothing concrete, and no definitive guidelines yet from any city that I know of. Although, some people in San Francisco has already run into trouble with 2 PWs mounted traditionally on the wall (installer had no idea of changed rules).
The headline "Millions without power." Lol Talk about making something out of nothing.
In the article, you can clearly add up the estimates and it doesn't even add up to a million throughout entire northern half of CA.
That's because Inverters have absurd anti-citizen anti-islanding software built in. For that to work:So if I wanted to take advantage of my solar panels on the roof, I thought, throw the breaker to disconnect from the grid, run a cable from the 12v power of the Tesla to a 240v inverter, wire that into the breaker panel and turn it on. This should wake the inverters under the panels and they should start producing power. Then I can plug the car into the wall and it will charge the car, thus completing the circuit.
Not sure what would happen to the excess power generated... Guess I could plug in the refrigerator too.
As is mentioned in the article ("Overall, power to about 800,000 customers is expected to be shut off, leaving more than 2 million people in the dark"), customers != people, since e.g. entire apartment complexes can be a single customer for PG&E.The headline "Millions without power." Lol Talk about making something out of nothing.
I believe the Sacramento location is powered by SMUDI just got my car at the end of the month and we're doing our first trip from San Jose to Truckee in the Tesla this weekend.
Looks like I need to stop somewhere along 80 for about 10-20 min to get up there (the way back you don't need to charge). Looking at the two maps Vacaville "might" be outside of the blackout. Both Sacramento chargers are in the clear. Roseville is also on the edge of blackout territory. Rocklin is likely out. Chargers in Truckee itself look good.
To not overly worry my wife, I'll probably to try and stop in Vacaville or Sacramento.
I wonder if the "in car" nav will tell us if it's up or down?
Yeah, it took MASSIVE loss of life and homes last year (Paradise fire) before they did this, but it seems like there should be a better way to maintain their equipment without such severe measures - but then again they're either in bankruptcy or about to declare......
Checked earlier and our address was on the #PSPS site as in the shut off zone. Not sure if it goes black at midnight or what. Will say that I've heard about the decision to shut on the radio, TV, alert by home phone and text alert on my iPhone. Ten-day Wunderground for my area didn't look too bad in general, temps not as hot, and winds weren't that bad either but the ranges around me are the crucial factor. Figure if I wake up and no power it looks like I can drive a little bit and at least get hot meals. Showered tonight for warm water and a hair dryer. Devices are charging. Really not sure what we can expect.
Not to mention of course that their "solution" to the fire issue is completely ridiculous. They should invest in installing safe equipment, clearing brush where necessary, and place observers in critical areas. But obviously saving money in the name of "shareholder value" trumps all. I hope all this will have consequences for their management.
My 3-year old solar/battery system automatically kicks in when the grid goes down and automatically reconnects.The reason most grid-tie solar systems don't let you provide power when the grid is down is twofold. First, they don't want to light up the linemen who are repairing the lines. Second, when the grid comes back up, the inverter has to get in sync with it phase-wise, or else you'd have a very dangerous situation, and it's a lot cheaper and easier to just shut down and wait until you have a signal than to disconnect from the grid, wait for a signal, momentarily shut off the inverter to resynchronize it, then turn back on the inverter and connect back to the grid. There are, of course, grid-tie systems that do the latter; they just cost more $$$$.
The report recommended that the state waive and streamline regulatory requirements and direct Cal Fire to immediately begin 35 fuel reduction projects, such as the removal of dead trees, brush clearing and prescribed burns to create fuel breaks, defensible space and safe travel corridors on 90,000 acres of land around cities and towns vulnerable to wildfires.Sounds better than raking the forest.
I thought it was interesting that we lost power in Lafayette around 11:15PM last night, but my co-worker who lives half a mile from me got chopped 30 minutes before that.
Current state in case anyone's wondering: Powerwalls kicked in, but our home network went down due to AC frequency issues (well known on the Tesla Energy forum here), which caused a bunch of other problems that didn't seem real important to solve at oh-dark-thirty. Woke up this morning to a more sane state, got the network put back together. Solar running the house and recharging Powerwalls now.
Bruce.
