So heres what happened:Bjorn demonstrating what happens if you only have 16 Amps available. At -11C it took the battery 45 minutes to warm up enough to start to charge (1 degree/2 minutes, battery needed 10C to start charging).
Bjorn video low temp AC charge at -11C
Since the RWD only has 3.5kW battery heating available from the single motor, it will presumably also have the same limitation at these very low temperatures, and require 30+ minutes to get warm enough to start charging. Although a 7.5kW charger has more power available, the car cant use it to heat the battery faster, so it wont help until the battery warms up.
My car is currently at 85%, and IO schedule 3 half hour charges with gaps, lets see how it gets on......
12-12:30
2.30-3
3.30-4
It’s not “charging”, but no you can’t force the car to use its battery to heat the cabin up. If it’s plugged in it will always use shore power for heating/ac. The only way to do it is to pull the plug unless there is a way in the zappi to disable power between certain time periods.How do I stop the car charging when I have the cars heating set to go off in the morning?
I have a zappi charger. Now on IO I have to leave it in fast charge mode. IO then controls the charging in the night, but it dosnt stop the car from starting to charge at 6.45, when I use TeslaFi to turn on the heating. Is there a way I can stop it drawing current (@ high day time rate) and just use the battery power instead to heat up?
Thanks. Do you think it would work if I set the zappi to boost for the time period of IO and leave it in eco+ at other times?Probably would need to do something in hardware such as connecting the eSense input wiring to a timer controller with the Zappi charger configured to stop charging output power on that signal.
If it's scheduled in the Octopus app it should be off peak.Sorry if this has been asked before. I woke up this morning to find my car didnt charge and to be fair i didnt check for a schedule last night. This morning i told the all to have the car ready by 9am and its giving me a 1hr slot to charge on the app, would this be at the peak rate or kff peak rate?
Many thanks
Some people do use Tesla settings to block the initial change & others like me just plug in using FAST on the Zappi & manually stop a few seconds later. Both approaches seem to work.Hey - Quick one, picked up my MYP yesterday so I am going to look to switch today from GO to IO. I have a Zappi and set it into FAST - In the setting for fast I have turned off charge when plugged in. Question is, will IO work with this setting as IO should just then schedule a charge and I wont have to worry about it starting a charge whenever I plug the car in?
Also, I assume if I didn't want to use extra windows I could just set a charge schedule on the Zappi to 11:30-05:30 and be done with it? (main reason for wanting an exact window is that if I don't set a charge window for my battery storage the Zappi will pull from the storage battery as well as from the Grid)
I'm not sure what changing settings in the Zappi itself would do as I believe IO just wants a totally 'dumb' charge device it can fully control.
I have two sets of batteries, both with separate inverters/apps and I've set them to block discharge overnight so car charging only happens via the IO slots & always from grid only.
It will likely give you some more slots shortly.Brilliant thank you for that information. I have now successfully done the test charge etc… and have an initial charge window of 02:30-03.00am lol don’t think it will be getting from 64%-80% in a half hour hahaha
I’m hoping this is an initial charge thing?! Or maybe wait till 17:00 and it will give me some more slots
The plug-in charge setting only applies to Eco+ mode as some cars need to see a working charger when first plugged in otherwise they write it off as faulty. Teslas do not require this setting.Hey - Quick one, picked up my MYP yesterday so I am going to look to switch today from GO to IO. I have a Zappi and set it into FAST - In the setting for fast I have turned off charge when plugged in. Question is, will IO work with this setting as IO should just then schedule a charge and I wont have to worry about it starting a charge whenever I plug the car in?
I'd also like to understand why it would be preferable to integrate to the car vs the ohme charger. Can anyone explain the pros and cons either way?Can I ask as to the reasoning to such recommendation?
