Number one and most important: no matter what your IHD says, your off-peak period stays between 00:30 and 04:30.
The FAQ about summertime on the Octopus web site is awful. There's about a page of waffle talking about IHDs (does anyone use these things?), but it never actually explicitly says whether the slot remains on GMT, or moves to BST. You might infer it, by this phrase
But it's still ambiguous because if it "stays", it implies no change, which means it stays on GMT. All they had to do was mention the time zone and the times - less than half a line - but we get a page of waffle.
Thanks all, think I’ve found the answer in my OHME app
1.30 - 5.30 BST according to them
I have to say that I didn't give this a second thought
Thinking about it, I started with 'Go' last August and when DST changed in October nothing changed in my account to suggest that I should have changed my charging habits.
Unfortunately, that's anything but clear. What does "Stays" mean? - does that mean stays on GMT?, or stays on local time? If it's local time, then the slot doesn't "stay" - it moves forward an hour.Octopus make two clear statements:
"Number one and most important: no matter what your IHD says, your off-peak period stays between 00:30 and 04:30."
Perhaps the best solution would be to ask Octopus ?... and as far as I am aware that is wrong...
"This SHOULD be straightforward – but some customers have noticed that their in-home display (part of the smart meter infrastructure) shows the cheap rate kicking in at 01:30 following a clock change."
If the app is showing 1:30 then it too is wrong.
That is ambiguous, this is what clear looks like :
That says off peak 9pm to 7am GMT, so tonight that off peak would start at 10pm?That is ambiguous, this is what clear looks like :
True, it says what it says, but doesn't clarify what happens when clocks change during the charge period.
