Actually the car does not send the pilot signal to the wall charger. It's the other way around. The EVSE generates the pilot signal and the car manipulates it, along with the EVSE, to establish a form of 2-way communication.
@supersnoop is correct that the wall charger can't really initiate the charge. But it can tell the car to stop charging, and a few seconds later tell it it's OK to start again. Wash, rinse, repeat...
Ah, ok. Thanks for clarifying! I guess that makes sense. But it's still that manipulation that is controlled by the car (which is why I was thinking backwards...)
So the key words in what you wrote are "
OK to start". If the car is done charging, it shouldn't take the bait and actually start, right? Somebody flinched here, and
@hjr's observation is that the Clipper Creek charger cycles its main relay, so I'm guessing it's sensing something that isn't (or isn't intended to) be there.
Question to
@hjr: when the CC charger cycles the main relay, is it a quick click-thunk, or is there a significant, perhaps variable delay (many seconds) between the off- and on- transitions?
Something probably unrelated, but while I'm speculating, I thought I'd toss this out there too... I took a trip in the car today, and returned just before dinner. A little warm out, but not too bad. Plugged the car in to the home system (Mobile adapter to dryer plug), and it started charging as normal. Then the main house A/C came on, which seems to be ok, load-wise, but I have a dual system and thought if all three get going it might be too much. I think they're all on the same 50A breaker... Anyway, I hit the Stop button on the car VDS,
but left the car plugged in. A little while later, I hear the car charging. I didn't start it, and it's set to charge on plug-in. I'm guessing there was a glitch on the 240v line when the house A/C cycled, tricking the Mobile connector / car to start charging as if it just got plugged in. So, something really seems to have a hair trigger... Perhaps these CCreek HCS-40 installations have something glitchy on their power or pilot signal lines?
Edit: Or, perhaps the daily SOC check just kicked in and started the charge... Will check the logs when it's done.
Er, double Edit: Can't be the daily SOC check - that occurs 24hrs after the last charge ends. That won't be until tomorrow... Back to the glitch theory?
