odd happening on dashboard
Discussion in 'Model S' started by medphys, Feb 15, 2017.
Tags:
  1. medphys
    medphys Member
    Chesapeake Va
    Has anyone seen this on your speedometer?Notice the hashed line in the bottom right of the speedometer section. Goes away after about 20 min.
    Thanks
  2. Sir Guacamolaf
    Sir Guacamolaf The good kind of fat
    My Model S
    Regen limited because Tesla is feeling cold.
  3. Veritas1980
    Veritas1980 Electric Viking
    Malmö, Sweden
    You have reduced regen due to a cold battery. Since your battery pack is cold, the car limits the amount of power going into the battery.
    It disappears when the battery is heated during driving or charging.
    Edit: dammit! too slow :p
  4. MorrisonHiker
    MorrisonHiker S 100D 2019.16.2
    Colorado
    If it's really cold, you'll see a dashed line on the top as well, indicating limited power available. I have a loaner this week and had both lines yesterday. I parked it in the garage last night and charged this morning and only had the regen line this morning.
  5. croman
    croman Active Member
    Chicago, IL
    I hit the power limit once when it was -22F earlier this winter. I barely accelerated and the car rebelled. It throws up a yellow exclamation sign and the car meeps sadly. :(
  6. EdA
    EdA Model S P-2540
    Massachusetts
    Charge to 100% that will also limit your regen (completely at first)
