I'm installing a set of OEM Tesla bluetooth TPMS sensors on a set of Martian wheels. When I test fitted them on the wheels, the sensors do not sit flat on the wheel barrel. Is this normal for the OEM TPMS sensors? Not sure how they mount on OEM Tesla wheels or if the space would be an issue?
Also, when I removed the stock wheel I noticed a loose bolt on the brake rotor. After some searching it sounds like it's a bolt used to secure the rotor during assembly that was left on and came loose. The Martian wheels fits over the bolt fine, should I just leave the bolts on there? And how tight should the bolt be tighten?
