OEM Goodyear F1 Tire Foam Detachment
Discussion in 'Model Y' started by DriveEV, Mar 1, 2021 at 1:59 PM.
  1. DriveEV
    DriveEV Member
    New York
    Hey all,
    More a PSA than anything else, but a long story short, felt some wild bucking/shaking over 50mph in the front end in my Y a few days ago. Took it into SC and they discovered the foam in the front right tire was completely detached from the tire. Perhaps the adhesive failed.. Anyway, just something to think about if you have front end shaking at speed where there is no obvious puncture, tire pressure issue, wheel balance or weight issue.
    EDIT: Only had 700 miles on these tires.
    • Informative x 4
  2. Balthezor
    Balthezor Member
    NJ
    Same thing happened to me. I thought it was a loose lug nut. Scared the *sugar* out of me. Went to SC and it was this. They rip it off because they didnt have a spare but replaced it 2 days later. I couldnt tell a difference between having foam or not.
  3. DriveEV
    DriveEV Member
    New York
    Wild! Thought a lug nut was loose as well. Felt like the wheel was going to come off.
  4. Balthezor
    Balthezor Member
    NJ
    I was so scared, I went to a tire place near my work. I work 50 miles away from home/SC. So no way in hell I was going to drive back with that risk.
    Honestly don't think the foam does anything. It's still loud.
  5. patnshan
    patnshan Member
    Milwaukee, WI USA
    Wow, that's crazy. I had this happen on my MDX once. It was because of a piece of ice frozen in the rim causing the balance to be off. Just posting in case this happens to someone, they may want to check for snow and ice packed onto the wheel.
