I don't know what alloy of aluminum the wheel is, but aluminum loses a lot of strength after welding if it is not properly heat treated. The heat treatment might compromise the benefits of the forging. So it could probably be welded to look pretty, but it's probably not going to be strong.
6061 aluminium alloy - Wikipedia
Typically, after welding, the properties near the weld are those of 6061-O, a loss of strength of around 80%. The material can be re-heat-treated to restore -T4 or -T6 temper for the whole piece. After welding, the material can naturally age and restore some of its strength as well. Nevertheless, the Alcoa Structural Handbook recommends the design strength of the material adjacent to the weld to be taken as 76 MPa (11,000 psi) without proper heat treatment after the weld.
