Off-peak Hours confusion…
Discussion in 'Model 3' started by kriskeyman, Dec 27, 2020.
  1. kriskeyman
    kriskeyman Member
    SF Bay Area
    With the new update, I’m a bit confused by the ‘Utility off-peak rates end at’ verbiage…
    From PG&E utility: Off-Peak (lowest price) – before 4 p.m. and after 9 p.m. Monday through Friday and all hours on weekends and most holidays.
    As such…
    Peak rates = 4-9pm
    Off-peak rates = 9-4pm
    Does that mean I should set ‘Utility off-peak rates end at’ to 4 p.m.? How will the car know to begin charging at 9pm?
    REALLY wish it would just let me put in the peak rate range o_O
    • Like x 4
  2. TheWhiteEGG
    TheWhiteEGG Member
    Calaskavada
    From 9:00 PM to 4:00 PM (next day), your cost of electricity will be lowest.
    Charge at night starting at 9:00 PM for the lowest price
  3. AxlxA
    AxlxA Member
    Bay Area
    is this new charging option in the latest update? I haven't even checked. I like to set 15mins after the offpeak begins to eliminate any guessing. I dont wanna give PG&E 1 cent worth of peak usage.
    • Funny x 2
  4. kriskeyman
    kriskeyman Member
    SF Bay Area
    Thanks for the response, but that is not answering my question. What time should ‘Utility off-peak rates end at’ be set to?
  5. kriskeyman
    kriskeyman Member
    SF Bay Area
    Thanks for the response, but that is not answering my question. What time should ‘Utility off-peak rates end at <time>‘ be set to?
  6. power.saver
    power.saver Supporting Member
    Arcadia, CA
    4pm
  7. kriskeyman
    kriskeyman Member
    SF Bay Area
    Thanks. How will the car know to begin charging at 9pm.. when off peak begins?
  8. power.saver
    Arcadia, CA
    The charge start time is calculated based on the amount of charge needed and the charging rate. So it could be an hour before 4pm for a quick charge, or 12 hours before 4pm for a long charge.
    • Helpful x 2
  9. southwo9
    southwo9 Member
    Santa Rosa, CA
    I have the same complaint - it should let you put in the hours that ARE peak and then not charge during those hours. I want to be able to get home at 6 pm and plug-in knowing it won't start until off-peak time starts (9 pm, same as you).
  10. 1.21GW
    1.21GW Member
    Michigan
    I think you guys are making this harder than it needs to be.
    you can schedule your car to begin charging at a certain time (I.e. 9pm) or you can schedule your car to be ready at (~7am). If you use the departure option, it will stop charging at your scheduled time OR when peak rates start. Whatever occurs first
    most of the year I have mine set to start charging at 7pm. But in winter months, it’s nice to have the scheduled departure so my battery is warmer.
    • Informative x 2
    • Disagree x 1
  11. Noodles
    Noodles Member
    Torrance, California
    I wish Tesla was smart enough to figure this out by itself
  12. Brock-WI
    Brock-WI Member
    Green Bay, WI
    We are talking about the new update here
    The new update removed the "start charging at" time and now only has a "Utility off-peak rates end at" time. Well this is useless. I totally agree I would prefer a charge between x-x times Our off peak rates are 8p to 7a So I set it for 6:30a so it wouldn't charge past that. Got home at 6p and plugged it in and it started charging right away saying it would be done in 2hr and 30min. What the heck? So I unplugged it, checking all my times and waited until about 10p, in the off peak time, plugged it in and sure enough it just started to charge right away. So that doesn't work at all.
    At least the way it used to be I set it to start to charge at midnight knowing it would never take more than 6 hours and at least that worked...
    • Disagree x 3
  13. swaltner
    swaltner Active Member
    Kansas, USA
    That’s wrong. The new software has two modes. They are “scheduled departure” and “scheduled charging”.
    You’re in Scheduled Departure mode. Click the “Switch to Scheduled Charging” link to change modes to how you want it to behave.
    • Informative x 3
  14. Brock-WI
    Brock-WI Member
    Green Bay, WI
    I see, but how is the scheduled departure at with an off peak done at time suppose to help? I don't understand...
    How I want it to behave is to set a time it can start charging at and stop charging no matter what by xxx.
  15. AxlxA
    AxlxA Member
    Bay Area
    Why doesn't someone just try it out? Not me, I cannot afford PG&E's peak rate on EV2-A =p
    I sort of wish car can talk to my powerwalls and learn the peak hours from there.
  16. St☰v☰
    St☰v☰ Member
    SoCal/Texas
    Correct, press the schedule button... here's mine and I'm running 2020.48.26:
  17. St☰v☰
    St☰v☰ Member
    SoCal/Texas
    #17 St☰v☰, Dec 29, 2020
    Well, first, you need to contact your local electric company and ask them specifically what their off peak hours are and then schedule your charger to come on at the time they tell you. Mine comes on at 9PM and then goes off well before the off peak ends the next day.
    For instance, I merely googled and came up with the below times and rate structure. 50 cents versus 9 cents is a big difference:
  18. Brock-WI
    Brock-WI Member
    Green Bay, WI
    I am very well aware if when our off peak is as I posted that above, which is 8p to 7a.
    Steps again
    1. Schedule Departure
    2. Car will charge during off-peak hours to depart by 8:00 AM
    3. toggle Off-Peak Charging on
    4. Select Weekdays
    5. hit the "Change off-peak hours"
    6. set "Utility off-peak rates and at" 7:00 AM
    Now what I assume will happen is the car would calculate backwards from 7a and start charging when it thought it should start charging to be done by 7a. So what does the depart time by 8:00 AM do if I have the "Preconditioning" box off? I just don't want the car to do something else like warm up the battery. Or will all it do is set a to be done at time, like our Leaf does?
  19. freeAgent
    freeAgent Member
    SoCal
    I find Tesla's charging configurations to be a bit confusing, but I'm also new to the car. In any case, I've worked around it by setting up my EVSE (Chargepoint Home Flex) to disable charging during peak hours. That way I know that no matter what I have the car set to do, I won't be charging during the peak rate period.
  20. DaveRZ
    DaveRZ Member
    SoCal Fwy @ 8MPH
    #20 DaveRZ, Dec 30, 2020
    I set my "off peak end time" to 12PM (noon) - My on peak is 12PM - 6PM M-F, everything else is off peak.
    Well, today I came home at 2PM (during Peak time), plugged in, and it immediately started charging. It turns out I never hit the "SET" button after setting all my options. So while my fault, it's still a very clunky interface
