Anyone else have a problem that it's too hard to put wheels on a hub since they get stuck on studs?
I have a feeling that holes drilled without correction for a paint thickness. I had to use impact on all 4 wheels nuts to push it forward, while stock wheels don't have such problem. Not sure how to take them off now...
Wheels looks beautiful though, weight is low. I will post photos later.
I’ve had 4 sets of Signature wheels and they fit fine through the studs, but corrosion can build up on the hub/hub lip and wheel making it hard to install or remove the wheels. Make sure you clean corrosion off the hubs and the back of the wheel in between wheel swaps with a 3M Scotchbrite pad/sponge. I always put some antiseize compound on the hubs and wheels as well.
I would take your car to a shop to double check that you didn’t damage the studs in case the bolt pattern is wrong. Hopefully it is only a bit of corrosion on the hub lip and you can get your wheels off with a little bit of muscle.
As @dmd2005 noted, it's likely the corrosion on the hub. You'll have to really clean it, and then it goes on much easier. It's also worth putting some anti-seize on the hub to reduce the likelihood of the corrosion building back up.
