Offset for aftermarket wheels? (10.5" rears)
Discussion in 'Model S: Driving Dynamics' started by Fonzie, Sep 16, 2013.
  1. Fonzie
    Fonzie Member
    South FL
    I'm assuming if I do 9" fronts, they will stay at 40mm. If I want 10.5" rears, anyone know what offset to go for? Would that differ depending if the aftermarket wheels were 22" vs 21"?
  2. Dreamin
    Dreamin Member
    SoCal
    #2 Dreamin, Sep 16, 2013
    I don't believe 9" with a 40mm offset will work. It'll put an additional 1/2" of wheel "inward" (compared to factory 8" wheel)... there isn't a lot of space between the top of the tire and the suspension... you can check with your hand/finger.
    And search the Vossen thread, it lists the offset they use for their 9" and 10.5" setup.
  3. Dr.Ling
    Dr.Ling Member
    Norge
    #3 Dr.Ling, Sep 17, 2013
    I agree that the info on the Vossen CV1's is useful. From what I recall those wheels are like follows (disregarding the change in wheel diameter and tyre choices):
    22x9 et30 = Wheel is 16,35mm further out towards fender lip, and you gain 3,75 mm between the suspension arm and wheel (compared to stock 21x8,5 ET40 wheels)
    22x10.5 et38 = Wheel is 27,4mm further out towards fender lip, and 23,4mm further in towards suspension.
    From what I can see from pictures of the suspension there's not much room between the front wheel and suspension arm, but most 9" wide wheels I've seen have ET35 offset or lower, and shouldn't be a problem.
    In the rear there seems to be lots of room between wheel and suspension, but someone who actually have done some measurements should post in here.
    (post edited: I posted my 20" options for the CV4's previously :redface:)
