For those that don't recall or weren't here, the Model X prototype looked like this. Looks really similar to the Model 3 cabin from the reveal but the final product certainly looks more integrated.
This is not true. One reason that this is not true is if the software collects a bigger dataset to work on then it was designed to do, or that the developers cared to test with. Two good examples here is old windows with it's infamous registry, and reports from Model S/X that never forgets a navigation, so when the navigation log starts to get long, the touch screen starts to be slow and may freeze and you have to manual remove old navigations from the log to make it stable again.If you had a set piece of software that never updates and adequate hardware then there should never been a lag time greater than then the system was first installed.
You are making a blanket assertion about all touchscreen devices. If you have a touchscreen on, say, a simple appliance, it will not magically become laggy over time. Likewise even on a smart device if you had a real time OS and programmed interrupts correctly then even if there's something else processing a large dataset, you shouldn't have lag for UI elements or buttons acting as switches. Currently Tesla isn't using a real time OS, and they are using underpowered hardware. As for Tesla navigation, they could solve that problem by chunking the data and loading on demand.This is not true. One reason that this is not true is if the software collects a bigger dataset to work on then it was designed to do, or that the developers cared to test with. Two good examples here is old windows with it's infamous registry, and reports from Model S/X that never forgets a navigation, so when the navigation log starts to get long, the touch screen starts to be slow and may freeze and you have to manual remove old navigations from the log to make it stable again.
Whoever's fault it is, it is a problem that doesn't exist with physical buttons.
The Tesla Model 3 touchscreen *must* include faster HW. They're not putting in Tegra 3 - they're just not.
Therefore, we should see some new touchscreen HW on MS and MX this year.
(No way Tesla is rolling out brand spanking new 100k model S/X with 5 years old graphics HW, at the same time equipping their low budget model with the latest tech.)
No. I'm making a "blanket assertion" on any computerized device, with or without a touchscreen. The old windows I was talking about did not normally have a touchscreen.You are making a blanket assertion about all touchscreen devices.
It does when the physical buttons trigger software on the backend...
Yes, *that* problem has an - to us not involved in the software development of the car - apparently easy fix. But it isn't fixed yet, and I assume the software for the Model 3 to be made by the same developers that made the software on S+X. But again, this was just two easy examples of why your statement was incorrect in the way you wrote it.As for Tesla navigation, they could solve that problem by chunking the data and loading on demand.
As you self said in your next post:
... and an another "easy fix" for problems like this is - and has been for a while - to "just throw more/better hardware at the problem" - like you proposed - instead of fixing the real problem(s) in the software.
If the microwave did log all cocking done on it over time, and had a finite storage for this log and/or had to somehow process this log each time it was used, yes, it would get more laggy with time. Or if it had some other form of software bug (and yes, the scenario above is in my opinion a bug) it could also happen. I do not say that it will happen on every form of device/all software no matter what, just that it may happen. Normally as a result of some form of bug in the software. One type of bug is to not consider how much data that will be collected over time.If you had a microwave with a touchscreen and on the backend had a microcontroller powered by software you're saying it'll get more laggy with time? It's simply not true of all devices.
The registry on this old windows versions I was talking about would still get full if you never updated windows. But yes, it had - just as the navigator on Tesla cars - an ever increasing datasets, a problem the developers did not foresee as they developed this system.You said my statement about software that doesn't update being not true... then you cited Windows which both updates and has ever increasing datasets...
But even if they provide faster HW in the M3, and have no lagginess or latency out of the factory, a few software updates later the hardware will become laggy, just like every touchscreen ipad or phone ever built.The Tesla Model 3 touchscreen *must* include faster HW. They're not putting in Tegra 3 - they're just not.
Again this has nothing to do with physical buttons or the touchscreen itself, just with the software. You can have an infotainment system with no touchscreen (only buttons or with that dial thing some of them have in the central console) and if it is update-able, it'll still be susceptible to lag as it ages.But even if they provide faster HW in the M3, and have no lagginess or latency out of the factory, a few software updates later the hardware will become laggy, just like every touchscreen ipad or phone ever built.
This doesn't happen with physical buttons and switches in a normal car, therefore this new technology is inferior to the cheaper technology it is replacing. Being "more awesome" straight from the factory doesn't outweigh being less functional and laggy 10 years later.
Can't integrate the screen in the manner of Model X without raising the dash significantly. Unlikely change considering we're at release candidate not prototype.View attachment 223180 View attachment 223181
These kinds of problems are non-existent in a $35k car. Maybe if you had a favorite radio station and hit that button several times every day for 30 years, then the buttons might start giving you issues...Physical buttons have their own problems, they can fall off, get stuck, or just plain become unresponsive (for various reasons).
Oh god, I really really hope Tesla doesn't go the planned obsolescence route. OTA updates mean more advanced software over time that could become too advanced for the hardware (looks like it already is). We deal with that kinda bullcrap every year on an $800 phone, and that's one thing, but on a $35k car? Tesla could have us by the balls here.You are making a blanket assertion about all touchscreen devices. If you have a touchscreen on, say, a simple appliance, it will not magically become laggy over time. Likewise even on a smart device if you had a real time OS and programmed interrupts correctly then even if there's something else processing a large dataset, you shouldn't have lag for UI elements or buttons acting as switches. Currently Tesla isn't using a real time OS, and they are using underpowered hardware. As for Tesla navigation, they could solve that problem by chunking the data and loading on demand.
...but does it turn red and go back and forth Cylon / Knight Rider style?I think the Cadillac "Super Cruise" option got the "spaceship controls" Elon promised M3. LED auto steer indicator imbedded in steering wheel, and facial tracking camera on top of steering column to monitor drivers attention to the road.
