The stock battery for the Model S is 3rd party part made by
C&D Technologies and
AtlasBX the Model 3 & X
Also Magnuson-Moss Warranty Act allows you to use aftermarket parts. That doesn't mean Tesla will always do it for you, but with a battery that exceeds stock specs, and reduces the weight, it makes it easier for them and they don't have deal with you on warranty claims.
Pre Refresh Model S: C&D Tech: DCS33-UNCR. 33Ah
Post Refresh S: AtlasBX U1 AGM battery. 35Ah
Model X:
AtlasBX 60B19RS. 40Ah
Model 3:
AtlasBX 85B24LS 45Ah
Tesla installed my
OHUMMU when I direct shipped it from
OHMMU to the service center at Tyco road in Tysons VA
12 Volt Battery Compendium | TeslaTap
And yes I noticed a significant increase in my aftermarket stereo performance when pushed above 6+ to 11 on the audio dial post install of my new
OHMMU battery. In fact several stereo shops use LiPo to help supply stable high demand power without adding additional weight to the car, same in the boat and RV markets.
Here's why:
4 years full-replacement warranty
Proprietary 12V Lithium cell and
BMS technology that is a drop-in replacement to your existing battery (no firmware changes needed)
B
attery Management System prevents damage to battery in extreme situations and also balances the battery cells to maintain the pack for longer service life!
>40Ah true Lithium capacity on 5hrs discharge test (more aggressive test than any Lead Acid test)
Easy to carry handle and only 9lbs weight
>2000 full charge/discharge cycles!
Tested in extreme climates and automotive conditions for reliability and performance.
Why go Ohmmu?
1. Increase reliability
2. Longer lasting (more life)
3. Decrease weight
4. Increase capacity
5. I
ncrease power (no voltage sag, better 12v performance, especially for subwoofers/amplifiers)
6. Less waste (less batteries being used and less material in each battery)
7. Increase efficiency (Ohmmu 12v charges and discharges at a higher efficiency than Lead Acid/OEM)
