3PHASE
3PHASE
After reading this, I checked my notification log, and got the vcfront message on June 4 and June 5, but at night while it was plugged in. Installed v3 several weeks ago. On fsd beta 2022.12.3.20 too. I don’t drive the car every day.
This is what they are working on.After reading this, I checked my notification log, and got the vcfront message on June 4 and June 5, but at night while it was plugged in. Installed v3 several weeks ago. On fsd beta 2022.12.3.20 too. I don’t drive the car every day.
What's the worse thing that could happen, other than maybe it wouldn't install software updates?This is what they are working on.
According to the owner of Ohmmu, they are running about 10 test vehicles with an additional 10 coming online for test this week. They are going slow on the gen 4 until satisfied with test results. Perhaps ask to be a Beta tester for them.Hello guys… any update on your batteries? Now I am getting more of the vcfront messages…
If there are no alerts in the notification section makes me wonder if there was a change to the software in the most recent updates.I'm almost at 5 months from just charging my battery up with no more errors. Several updates and even had the car sit for over 2 weeks not driven.
Mine is the v2, bought last year June 2021.
Guess they are suggesting a new unused battery should hold more than 70% soc between manufacture and installation. If it’s below this it is either really old or faulty.Sentry doesn't draw from the 12V battery. It leaves the HV and DC-DC turned on all the time. It actually reduces load and cycling on the 12V, at the expense of 24/7 300W of draw on the HV pack.
What a weird procedure. At room temp, 12,4V OCV is about 70% SoC. They are literally telling you that any battery that is below 70% SoC must be discarded, independent of it's state of health. You're not allowed to recharge it.
This procedure is not just for brand new batteries from the factory.Guess they are suggesting a new unused battery should hold more than 70% soc between manufacture and installation. If it’s below this it is either really old or faulty.
Yes it is. The procedure quoted from the service manual is specifically for installing a NEW battery. NEW is mentioned 3 times in the quoted paragraph.This procedure is not just for brand new batteries from the factory.
Good info keep posting. It is possible Tesla changed the charging and maintenance profile. What are you using to measure the wave forms?The below waveforms are what I have been observing on my Braille battery, and perhaps show the background VCFRONT_a180 errors as being side effects of some testing/characterization that the car is doing. Are you all observing something similar?
Here's a voltage waveform with the cursor at the timestamp of a background VCFRONT_a180 error. On other days when I'd see the error in the notifications, it would always be preceded by a similar waveform with a rounded dip downward, then settle back at 13.3V for the rest of the night and into the morning:
Here's a more recent waveform after the update to 2022.16.2, where I no longer see all the repeating jagged peaks that would precede a background VCFRONT_a180. No errors occurred on this day, and it seems to stay at the 14.2V area for a much shorter time. However, it spends a lot more time at 13.4-13.6V :
What software version do you have?Weird, I now have an alert from 6/28 showing vc front error. It didn't show up a few days ago when I checked. I guess I should expect to start seeing 12v errors pop up soon.
I am on 2022.16.2What software version do you have?
Consider adding the battery monitor module so you can see what the charging system is doing when the errors are generated. Very inexpensive and takes 5 minutes to install. The V4 battery is supposed to correct this but the more data the better.I am on 2022.16.2
I am getting the error as a passive error. No active errors are shown when I get in the car to drive.
