OK to leave USB charger plugged in 24/7?
Discussion in 'Model S: Battery & Charging' started by eco5280, Mar 31, 2015.
  1. eco5280
    eco5280 Member
    Country
  2. brianman
    brianman Burrito Founder
    Nitpick: I would call this a 12V accessory rather than a "USB charger".
    Answering your question though, I suspect you're fine.
  3. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    I have one like this that I plug into the cigarette lighter and run the cord between the passenger seat so it sits on the floor in the middle of the backseats for my kids to use:
    Fonus Brand Two USB DC Cup Holder Cigarette Lighter Socket Power Adapter Splitter Double Car Charger Center with Dual Charging and USB Ports for Apple Iphone 5 (GREEN Dash Sticky Mat is included): Amazon.ca: Electronics
    I sit it in one of these cup holders:
    2007 2014 Tahoe Suburban Avalanche Yukon Console Cup Holder 19154712 | eBay
    I keep it plugged in all the time with no problems.
  4. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    Yes I do it, no problem. The USB ports are switched anyway (i.e. power to them is cut off when the car is off). Even disregarding this you'll be fine. I have dashcam hard wired to non-switched (always on) fuse and I left it on for 10 days at the airport (forgot to turn it off) in parking mode and no problem with my 12V battery after that either.
  5. Bulletproof
    Bulletproof Vendor
    Hawthorne, CA adjacent to the Supercharger & Desig
    We've never had a problem with leaving USB cables plugged in, or with any other EVs we tested. I'm sure the same applies for ICE cars.
  6. brianman
    Sometimes the nitpicks are important. The OP is asking about the vehicle's 12V plug not the USB ports.
  7. Johan
    Drammen, Norway
    So very right you were to point that out earlier. Still I missed it. The answer will be the same though for the 12V plug: it's switched too.
  8. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    12V and USBs have no power when the car is off. You are totally fine.
  9. FlasherZ
    I like to joke with people who ask me about the headlights staying on for a while or leaving an accessory outlet item plugged in: "The battery might go dead. In a month or two."
  10. eco5280
    eco5280 Member
    Country
    I know that - I'm wondering if putting a constant 4.8v draw on the 12v battery while the car is on is damaging to the 12v battery.
  11. CHG-ON
    Sorry. I would think not. That is not that big of a draw, considering that the main pack is constantly charging the 12V.
  12. ChrisPDX
    ChrisPDX Member
    Hillsboro, OR
    The adapter is actually pulling 12v from the port. Internally it drops the voltage down to 5v for the USB ports. So as far as the car is concerned, it's a 12v device pulling up to 24watts of power (assuming both USB ports are used at full capacity). I believe Tesla rated that port at 120watts, so you'll have no issues.
  13. hpjtv
    hpjtv Member
    Langley, BC, Canada
    The USB ports are always ON (Dec 2014 Model S) contrary to what everyone is saying. Only the 12V outlet is switched off when the car powers off. How do I know this? I have a constant USB charger plugged in one port and the light is always on (the cables with the LED at the tips), the other plugged into my lithium-ion battery pack which I connect to my cell phones and the unit says it's always charging. I've gone as far as plugging a dead tablet into it and come back hours later to find that it is fully charged. Since my dash cam uses 5V, I will be wiring it to the USB also now. And yes it is okay to keep accessories plugged in. If the 12V dips below a certain voltage, the main pack charges it back up.
  14. FlasherZ
    If true on your car, this is a change from earlier cars. My USB ports and accessory outlet all shut off when the car is off. In my Signature car, the USB ports are limited anyway in that they're only 1.0A ports, so we keep a charger plugged into the accessory outlet.
  15. jerry33
    Texas
    My earlier car takes a few minutes to shut off. If you don't check, it might appear that it stays on.
  16. snellenr
    snellenr Member
    Houston
    Sure - but it only works out to around a 176 ft/hour charging rate. A HPWC would be better...
  17. RiverBrick
    RiverBrick Active Member
    Québec
    In my car they go off if and only if I check the energy saving boxes which put the car into a deep sleep.
  18. hpjtv
    hpjtv Member
    Langley, BC, Canada
    I have the energy savings on but with Always Connected checked. Yes, I know the accessories take a bit to turn off once you lock/leave the car but my USB remains on all the time. My dash cam records 24/7 (it uses 5V) only when connected to the USB, not the 12V which turns off.
  19. jerry33
    Texas
    If I plug my phone in and turn the car off, it charges for one or two minutes (I've never actually timed it, but it shuts off before I get bored of waiting) and then stops. Energy savings on, Always connected off.
  20. hpjtv
    hpjtv Member
    Langley, BC, Canada
    Maybe keep always connected on and see what happens. I'll have to experiment with both and get back on this. It also looks like your vehicle is pre-auto pilot so there might have been some changes made.
