All of my previous cars (BMW, MB, Audi) have had a feature that allows the heat or AC to stay on for several minutes after I leave the car to run into a store or whatever. Based on my Googling Tesla does not offer this feature. Since we're a pretty smart bunch, I'm sure someone has come up with a workaround. I saw a post about leaving the door slightly ajar but I'm not comfortable doing that. Any other suggestions? Any thoughts one why Tesla would ignore what should be a pretty easy feature to implement?
Easy. Put the car in N, touch "Controls" - "E-brake & Power Off" - "PARKING BRAKE". This will enable parking brake, while car is in Neutral so it wont power off when you leave car
That would be the sensible thing to do rather than have someone break the window and drive away because it's in neutral. Lol
Do you ever have a problem where you turn it on via the app and it turns itself off after about 2 seconds? I usually have to turn it on twice. Although both suggestions work, it's really strange that one of the most technologically advanced cars in the world doesn't have such a feature.
I have seen the app not recognize that the climate is on. I've turned it on and had to change displays on the app (for example to Charge, then back) before it showed the climate actually on.
Phone app for me. The neutral/e-brake thing is for if someone wants to wait in the car while you go inside. I don't believe the car locks in that state.
Not exactly the same situation, but in a friendly area (or with people in the car while I step out) I leave the driver door closed but unlatched. Climate stays on, quick and easy to do. Car still can't be driven without fob or app.
If someone's in the car, having them tap the touchscreen after you close the door is easiest (in my opinion).
Yeah it's not ideal security-wise, i.e. if your afraid of people getting in your car while you're away. It's called "camper mode" and is actually perfect for sleeping or staying for longer periods of time inside the car
I use the app to turn it back on too... but while I'm at it, have another request: I wish the time the HVAC stays on could be adjusted, or at least set up to stay on longer when the car is plugged in. Often I turn on at home before I go out, but it will timeout after, what is it: 20 or 30 minutes and I have to remember to turn it back on again.
If you have the 8.0 firmware on your car just buckle the front passengers seat belt before you get out and the A/C should stay on for up to 30 minutes. (You could even use a seat belt extension device so you don't have to reach over to get the actual seat belt.)
I remember Elon saying that when Version 8.1 rolls out Tesla will enable always-on minimum and maximum temperatures. Problem solved. Ok, maybe not yet. Hopefully soon.
Get out of the car, but before closing the door, reach in with your right foot and push the brake "button" firmly. This will leave the car 'on' One button.
I use this method to get my mail. The boxes are on the side of a rural road. I hated getting out, walking across the street and then having the car go dark whle on the side of the road. I want the headlights, tail lights, and turn signal to remain on. The brake method works just fine. I don't know how long the car will stay this way; the 'shift to neutral mode' will last until the battery dies! You do have to press firmly - just like when engaging hill hold. The car should make the "da-dump, da-dump" error/warning sound. The handles will auto-retract (usually just about the time I get the mail and approach the car), but I don't know for sure if it auto-locks. You should experiment with that, or use the single click on the top of the remote to ensure the car is locked.
