No adapter necessary. It's the newer version of Tesla's HPWC so it will work as is. I took a leap of faith that they wouldn't change the port and have to deal with supporting two standards (S/X Vs 3).What type of adapter did you install??
Is the 72A unit that much heavier than the 48A unit?
No it is not.Pretty sure it's the same weight... 'cause it's the same unit. The 48A is a software limited 72A. .
No it is not.
Already mentioned up thread. Some of the early cars got a software limited 72A, but now they are physically different.It's no longer an option in the design studio since it's standard on the 100's and not an option on the 75s but when it was optional it could be upgraded via software... the dual chargers were hardware but I'm pretty sure the 48A and 72A are the same.
However... it appears this has since changed and the current fleet is limited to 48A physically and they CANNOT be upgraded to 72A...
Yeah, if they keep the same architecture (and assuming it really is a 2-3x 24A), I agree it seems likely that 24A might be the standard.That's interesting... I always thought it was a single 48A unit but it's 2 or 3 (for 72A) 24A units. I suppose it's possible that 24A could be the standard for a ~55kWh 3
Which realistically isn't terrible. I usually keep my charge rate set to 20A.... but 32A would be nice since that's the most common L2 public charger rate.
Even the newer Leaf does ~27A. 24A seems too slow for an otherwise highly advanced car.
I was just about to add this. My leaf does 6.6KW charging at ~30 amps. I don't think they will go with 24A since that would take about 15 hours to charge a 75kwh pack. 48 amps is what they already have on the shelf, well tested, charges is roughly 8 hours, seems perfect to me.Even the newer Leaf does ~27A. 24A seems too slow for an otherwise highly advanced car.
-Jim
I'm obviously not asking the correct question.No adapter necessary. It's the newer version of Tesla's HPWC so it will work as is. I took a leap of faith that they wouldn't change the port and have to deal with supporting two standards (S/X Vs 3).
What type of port did you install in your garage? Did you buy anything from Tesla to plug into that port?
Most HPWC are hardwired... I can see how the question would have caused confusion...
I don't understand why some people in this thread are trying to rationalize a reason for a 24 amp charger. There is no good reason for a weaker, slower charger! These cars need to be able to charge FAST!!! More! Bigger! Better! FASTER!!! 48 amps! 72! 80! MOAR!!!
In a few years, when EV chargers are much more commonplace, people will expect to be able to slam 30 or 40 miles into their battery while they are in the supermarket picking up a few things.
In a few years, when EV chargers are much more commonplace, people will expect to be able to slam 30 or 40 miles into their battery while they are in the supermarket picking up a few things. I want that now, and I won't even have my 3 until the end of the year or so!
