Older Teslas limited to 90kW Supercharging
Discussion in 'Model S: Battery & Charging' started by ckessel, Dec 5, 2013.
  1. dcopperfield
    dcopperfield Member
    Bothell, WA
    If this is true, I'm certain Tesla will replace/ fix whatever is needed. Seems silly to punish those of us early adopters with no higher- speed charging.
  2. Discoducky
    Discoducky Active Member
    Seattle
    I'll be hitting nearly all the I5 chargers next week so I'll know what a 60kWh can do with 5.8.
  3. andrewket
    andrewket Well-Known Member
    Vin just above 10,000, P85+, 5.6, Newark DE, hit 112kW today. Started with ~80 rated miles.
  4. wts13
    wts13 Member
    Southern California
    How do you see the kW rate? All I've seen is miles per hour.
    I remember seeing in the low to mid 200's on my 60. What does that sound like?
  5. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Multiply Volts * Amps and that gives you the kW. 120kW should be in the mid 300's for mph.
  6. cinergi
    cinergi Active Member
    MA
    You can change the settings in the car to show range vs. energy -- it's in the settings area (I forget which tab).
  7. wts13
    wts13 Member
    Southern California
    Ah I see. Perhaps Tejon Ranch, Harris Ranch, and Gilroy weren't yet upgraded to 120kW when I used them in October?
    Thanks, will try that next time
  8. mark
    mark Member
    Dallas
  9. ckessel
    ckessel Active Member
    BTW, someone asked my software version (I'm the OP). I have version 5.8.
    Tesla called me in response to my email to [email protected]. He said they'd looked at the logs and verified nothing was wrong with my car and that was I getting 90kwh because that's all my car's hardware supported. He spun it as "You're not losing anything, you still get the same 90kwh you got before the new superchargers came out".
    At the end of the conversation, he said he was going to go talk to more sources to get info, but I think that was more to my questions about knowing which cars had new support and upgrading the support. Given I'm on the latest software, I expect it's truly a hardware limitation.
    As I said, I'm VIN 2310. I know another 23XX here in Portland, OR also has capped out at 90kwh.
    I'd like to know where the breakpoint was, why those before the breakpoint weren't told, if there's an upgrade, what's the cost and is it impacted by the "hardware upgrades" in the prepaid service contract. Just a bunch of questions at this point as Tesla has touted 120kwh pretty heavily and I feel a bit hosed. I hope Tesla gets back with some more info at some point.
  10. walla2
    walla2 Member
    More Sig Tax / early adopter "benefits" I'm afraid. I love my car, I love Tesla, but don't buy a Sig.
  11. brianman
    brianman Burrito Founder
    If true...
    This, my friends, is a real tragedy. Talk about ruining a brand. :(
    I hope someone from Tesla with the power to do something about it, is paying attention to the destruction of the Sig branding.
    Based on the past though, I won't hold my breath.
  12. wts13
    wts13 Member
    Southern California
    This makes me wonder which if any existing cars will be compatible with 135kw if and when it is rolled out in the US...
  13. Fedderman
    Fedderman Model S 85kWh (VIN 1732)
    Palo Alto, California
    I have traveled the 101 corridor multiple times over the past few months, using the SC's in Gilroy, Atascadero, and Buellton. Even at low SOC (20-40 miles remaining) I have maxed out at just under 90 kW. Most recent trip was Thanksgiving week. I have an early VIN (1732) 85 kWh, and FW 5.8. Seems this is a hardware limit, and hoping (but not optimistic) that an upgrade will be included in my annual service this month.
  14. David_Cary
    David_Cary Member
    Cary, NC
    While I understand sig owners complaints, upgrades happen all the time. If they made a switch in some wiring at VIN 3000, are they really supposed to tell people who are pending delivery of VIN 2999 that they made an improvement and you can forfeit your deposit and wait for 3000.
    Communication as the 120KW rolled out - sure.
    But complaining that they made an upgrade - that doesn't make sense.
  15. Martini
    Martini Member
    Paris, France, France
    Everyone with a low VIN was happy to buy their car before they knew supercharging even existed. Complaining about something that by any measure is a bonus to your original purchase is just odd.
  16. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I wouldn't think that 135kw would come to the US at all. I think its a matter of the different in types of power and simple math. They have 3 phase power which added up equals 135kw, but we don't and under a similar config add it up and it reaches 120kw. I'm in my car now so can't lookup the details ATM but again I think its a difference of their 3phase vs ours... Not an expert on this though
  17. JohnQ
    JohnQ Active Member
    Redding, CT
    While this doesn't impact me, does anyone know what the charge time difference would be given the power taper that takes place? For example, if it tapers to 90kW after a 30kWh charge then the differential is approx 5 minutes in charge time (depending on the taper curve--that assumes a linear decline which I'm pretty sure it's not).
    Not saying it is 5 minutes, just an example.
  18. aaron.s
    aaron.s Member
    All
    FYI - Vin #3449 and I can charge at 120Kw.
    Aaron
  19. Chris
    Chris Member
    Maryland
    If this is all really true I think it would be a great opportunity for TM to make good on their 'hardware upgrades included' promise with paid service visits.
  20. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Power folding mirrors, parking sensors, 120kw charging ... eh ... just add it to the list.
