OMG I love it
Discussion in 'Australia' started by EcoCloudIT, Dec 12, 2015.
  1. WhiteStar
    WhiteStar Member
    Sydney, AU
    361 km typical at 90% on a P85D with 1700 km on the ODO.
    349 km doesn't sound unreasonable on a ~1 year old S85...depending on how many total Supercharges & Range charges.
  2. TesAus
    TesAus Member
    Sydney, Australia
    I also get 349km typical range at 90% charge at a little over 20,000kms.
  3. ICUDoc
    ICUDoc Active Member
    Sydney NSW
    At 2,500 km on my P85D, my 90% ("Typical" rather than ideal) is 364 km.
    Was 365 at first, now 364. On Tuesday, it said 363, but seems to have recovered:)
  4. raynewman
    raynewman Active Member
    Brisbane, Australia
    My 85 at 20,000 was 360 new - now 357+-1.
  5. mhh
    mhh Member
    Adelaide
    Dborn, I've lost count of posts where you have said you are glad you don't have a P85D and are totally satisfied with your current car. Methinks you doth protest too much. I think you are a closet D lover. I predict that you'll upgrade to the fastest Model S going when you next change cars. :p
  6. cdfleischmann
    cdfleischmann Member
    Northcote, Victoria, Australia
    What do peoplpe actually think about range charging and/or typical charges? I have my P85D car set at 80% for my charging, and in the 7+ weeks only done one range charge thus far.
    I also typically charge up to 80% and don't typically disconnect the car until it sys "charging complete"...
    What are peoples thoughts on;
    1. Range Charging, how often is ok, how often is bad? I plan to keep the car for 3 years, but trade in at 37 months.
    2. Disrupting over night charging from the home wall-mount.
    3. Disconnecting from the Superchargers before charging is completed.
    Any thoughts of wisdom greatly appreciated.
    Chris
  7. paulp
    paulp Active Member
    Adelaide, Australia
    I'm with you on all that, and the great part is that aston's head designer now works for tesla, hopefully designing a 2 door.
    - - - Updated - - -
    I have an 85 and an 85D. Both near identical other than the D. I drive them both almost equally.
    The D is noticably better handling, even in the city. Indeed it makes it feel like a smaller sportier car. There is an additional motor note up front, which I like. Havnt used the frunk in either yet. Having said that, the non D is also manificent and you couldn't be disappointed, its just that the D is magnificent plus a bit more. Around the city, the 70 is ample range. Never use the range of the 85's. Never use the full acceleration of either....so for me the P would be a waste.
    With a choice of keys on the hanger, I always go with the D.
  8. WhiteStar
    WhiteStar Member
    Sydney, AU
    I think you’re absolutely right to limit range charges to only when necessary and also to charge to 80% as standard. Cells generally operate best for long term durability between 80% & 20% SOC. Operating in that band will maximise typical range during the lifetime of the pack.
    The other consideration when proactively attempting to maintain typical range over the long term is to charge using the lowest current that is convenient i.e. limit current if a fast charge time is not a priority and limit Supercharger use as much as is conveniently possible.
    As far as I can tell, there are no negative consequences to disconnecting either Supercharger or HPWC prior to completing a planned maximum charge level.
  9. Daemon
    Daemon Member
    Canberra, ACT, Australia
    I leave my car at 70% for daily use, but my theory on worrying about high or low charge states is that if it's costing you time to charge more often now instead of a potential need to do the same thing in 5 years or so then you might as well make use of the range you have now. For example I just drove from Sydney to Canberra starting on about 93% and finished on 8%. I could have charged to 80% and supercharged in Goulburn but that would add 20-30 minutes to the journey.
  10. alpal
    alpal Member
    Melbourne, Victoria, Australia
    The Tesla grin - yes. Hard to describe but well done ECIT. Congrats!
    Here is mine at our annual street Xmas get together. Star attraction. I'm out of sight but wearing my grin.
  11. oystero
    oystero Member
    Melbourne
    You are not alone :)
  12. cdfleischmann
    Thanks WhiteStar... good to gather other peoples thoughts. Cheers!
  13. paulp
    paulp Active Member
    Adelaide, Australia
    I work to tesla's recommendation, that is I charge between 50 and 90%, and plug it in every night. I only range charge to 100% when needed, which seems to be never.
    Essentially I'm relying on the people at tesla knowing whats best for my battery rather than anyone else.
    your comment about stopping a charge before complete, its no issue. Think about it a different way. If you reduce the charge setting before you unplug, it will say 'charge complete' and you will happily unplug.
  14. Nickdp
    Nickdp Member
    not wishing to hijack this thread I have started new thread here
  15. One Gear
    One Gear Member
    Australia
    The typical range in my S85 at 90% has been steady on 354km for a few weeks now (442/443km rated). But that is with range mode 'on'. When specifying your range, you need to know whether range mode is on or off. Displayed range is higher (by a few kms) with range mode on. My car is at about 23,000kms and probably about three quarters of that is road trips. I usually have the car charged to 60% to 70% while at home.
    Maybe there should be a separate thread on battery health in Australian conditions?
  16. Dborn
    Dborn Confirmed
    Sydney, Australia
    Hmmm. I need to turn range mode on and see what I get, then. Turned it off a while back because my significant other needs it freezing in there instantly!
  17. raynewman
    Brisbane, Australia
    Since 7.0 even with range mode the freezing is pretty instant.
