oh, what's the story behind Coda Plaza..? normally it's ok...see S Class, big Jeep parked there. some spaces are more narrow than others, and there are those close to the walls which will be tough..cars cannot really go up and down in opposite directions at the same time but people tend to back off. Overall manageable unless during peak hours (Saturdays) where if you are left with one or two tight spaces, you have no choice.
On the same subject, was also wondering if there's any car park on the blacklist which is a definite "no no"...? whereas there might be a few there which is difficult, but ok for those with good driving skills (and i don't belong to this group!) ? thx
Lee Garden 2 where the exit at the payment machine is an upslope bend that driver can see how much to turn without hitting the machine. Wheels scratch warning.
would you allow a car lift that has ard 1cm space left after you put your car in? that's Regal HK. i wouldnt bother with the car park all together.
In the past, you can park at the basement but at a higher $/hr. Is it the case that the only choice now available is to park at upper storey by using car-lift ?
Kam Ying Court (錦英苑)multi-storey carpark, Ma On Shan
The entrance and the exit should be wide enough for a MS. But terrible to take right-angle turn round the walls when you ramp up and down the decks. I merely made those turns with all the sensors indicated "STOP".
There are 3 parking spaces between columns, you are lucky enough if you can take the slots on the sides. I parked at the middle slot and a SUV next to me parked closely to the column, however, an honest driver parked his NOAH right at the middle of the slot on my right, then I had no chance to get out of the car (I did try tilt parking or getting out from the rear door because the parking was full and it's the only available slot at the moment). So I would say the parking spaces are tight.
