On the rear air vents, does one side push way more air than the other?
Discussion in 'Model X' started by wisgary, Aug 1, 2017.
Tags:
  1. wisgary
    wisgary Member
    Washington
    I can't recall off the top of my head which side is which, but on my X, one side pushes air at a much higher volume than the other. Is that normal?
  2. verygreen
    verygreen Curious member
    TN
    that's a manufacturing defect.
    I caught it at delivery and added it to my due bill.
    The fix was to correct some improper duct connection or some such, so talk to your SC about it, I guess.
  3. bcampbelllds
    bcampbelllds Member
    North Dallas, Texas
    I noticed this too and the SC told me the blower is on the right side and will force more air on the right. He said it's normal, but will double check all connections to be sure.
  4. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    I think 70% of the air goes to the 3rd row and very minimal goes to the 2nd row. I can't fully close 3rd row vents
  5. wisgary
    wisgary Member
    Washington
    Do you guys have a ton of air on the rearmost rightmost side spot? It makes a lot of noise when compared to everything else when the fan is set to max.
  6. dragonxt
    dragonxt Active Member
    Bay Area
    I think I certainly do
  7. Rocinante2000
    Rocinante2000 New Member
    Dallas Tx
    My left side middle row air vent has almost no airflow at max fan setting.
  8. arubinst
    arubinst Member
    Ecublens, Switzerland
    Do you have a 5 seater?
  9. Jayrod
    Jayrod Member
    FL
    How can this happen in a 100K vehicle? I’m in Florida and will raise eternal hell if the AC doesn’t work well.
  10. tpham07
    tpham07 Active Member
    Baton Rouge
    99% of people don't have problems, otherwise Tesla wouldn't sell a model X anywhere except Canada.
  11. Jayrod
    Jayrod Member
    FL
    This is a true statement although how many Model X's exist ? I can't remember but I thought I saw the number somewhere. Sometimes I forget 3 and 4 responses on a forum don't constitute an issue so to say.
  12. tpham07
    Baton Rouge
    at least 100,000 Model Xes have been made.
  13. ps004ynos
    ps004ynos Member
    Los Angeles
    Our six seater has the same issue. Left side middle row has poor flow and obvious temperature difference (warmer air coming out). I spoke to SC literally 1 year ago, was told "it needs a part but it's backordered." It's not a huge issue but I've reminded the SC several times since and I get the same BS response. These things can be fixed but you have to make a row about it. Annoying.
  14. Rocinante2000
    Dallas Tx
    I have the 7 seater. Going in for repair next week.
  15. srharris22
    srharris22 Member
    Raleigh
    Can you follow up on here please? We just hit Warmer weather here a month ago and noticed this same issue.
    Very loud and very much stronger right side vs left
