LinkAirMan ResQ Pro+ Tire Repair Kit on Amazon.
Hi - which plug kit did you get or recommend?I have a plug kit for each of my EVs. No way am I going to fill up a tyre with goo which apparently then renders the tyre unusable. I also have a very low profile jack that can get the car up (if needed) when the tyre is flat.
I have not had to use the kits but they are there for Regional areas. Should work okay but not in sidewalls.
May not be an issue on 2022 models as the low voltage system is now 16v Lithium Ion through still 16A peak performance.I can't remember the brand of my plug kits. I got two different sizes- bigger for the Tesla and smaller for the Zoe.
One word of warning. I have a double acting tyre pump/compressor which draws about 12A but it goes up to 16A under load. Runs fine on the Zoe which has a 15A slow blow fuse. However, on the Tesla, the "soft fuse" goes and you cannot use the accessory socket for approximately an hour after this (Tesla has virtually no fuses). So the solution is to use alligator clips direct to the 12V battery.
curious if that gesture would make anyone a return customer?the guy there plugged it at no charge
Just bumping this post... making plans for what I need to take on my trip to Perth. I already have an electric pump (this one). Would there be any need for both the Tesla repair kit and the SCA one linked? Considering just the SCA one. Does anyone have any more recent experiences of various products to share?I have the Tesla Tyre repair kit which is a compact 12v compressor with optional goo. (No longer in the Tesla store). Along with a cheap spaghetti kit similar to this one SCA 8 Piece Tyre Repair Kit
