One pedal driving stopped working
MOBB
161
122
Bedfordshire
Car went in for some paint last week, when I collected the car the nav visuals went mad, but have since gone back to normal
However the one pedal brake regen thingy no longer works, are there any settings for this? Software is still 36.2.1
bit weird that the car was just in for paint and this happened :-(
DaveW
1,135
899
Beds, UK
It’s enabled under driving.
Mine was enabled by default when the update came in, but then turned itself off a few days later. Could be due to it being a driver profile setting.
It’s been fine since turning back on again.
eladts
661
808
Brookline, MA
There are two setting in the driving menu:
Regenerative breaking: LOW or STANDARD
Stopping mode: CREEP, ROLL, or HOLD
For maximum regenerative breaking make sure STANDARD and HOLD are selected.
I've been getting noticeably less regen braking for the last few day and occasionally get a message saying the regen braking is limited even when SOC is less than 80%
In cold temperatures regenerative breaking is limited until the battery warms up. That's normal.
NorfolkMustard
2,106
2,017
M3P w/FSD
This is due to the cold weather and in turn the cold battery. First regen is limited (IME below about 13ºC) then as it gets colder (IME below about 0ºC ) power is also limited, but to a lesser degree than regen.
Once the battery warms up through driving or DC charging the power and regen return.
WannabeOwner
5,758
2,893
Suffolk, UK
I've got a problem with it too.
It has stopped working on my wife's profiles . Car is new, so I don't have "behaviour has changed" history to compare with (but this is second Tesla, so familiar with the car and cold/winter driving). Other weird things have happened (when, as it happens, wife was driving - GPS and Auto Dip headilghts stopped working, they were cured by a reboot)
I suspect the 2019.36.2.1 update.
I have, last night, deliberately changed the REGEN to LOW and back to STANDARD
and I have also changed ROLL (which was set by default at the 2019.36.2.1 update) to HOLD and back to ROLL again.
I drove the car last night using her setting, and it seemed to be OK. She'll take it today and that will tell for sure.
Roy W.
Battery running low...
Jun 3, 2019
2,276
2,233
Derby, UK
Perhaps we should do a CTRL-ALT-DEL each morning? ;)
Backpacker42
26
51
Sunnyvale
Backpacker42
26
51
Sunnyvale
Had the same experience. Worked like a charm for a couple of days, then suddenly stopped working after I did a charge. Turns out the mode changed from hold. Changed it back and have not seen the problem since.
Reactions: WannabeOwner
MOBB
161
122
Bedfordshire
Yep it had changed to creep, I assume the SC did it somehow as the air con setting had changed along with the weird sat nav graphics issue.
Changed it back to HOLD and all is good now.
Thanks for all the replies :)
WannabeOwner
5,758
2,893
Suffolk, UK
I think there is a bug in the update.
Provided REGEN is at STANDARD rather than LOW that should give full regen (only difference should be at very low speeds depending on CREEP, / ROLL vs HOLD)
A reboot and/or toggling REGEN STANARD/LOW/STANDARD and maybe ROLL/HOLD or HOLD/ROLL and back again may "Set" the working value, even if the CONFIG value was already correctly set
rotor2k
470
244
London
Mine set itself back to Roll when I setup easy entry mode on my profile a couple of days ago (being on 2019.36.2.1). It messed up my seat position as well (after completing the easy entry mode position, when it reverted to "my" position it was nothing like it was supposed to be). Other than that, I haven't noticed any other settings that got surreptitiously changed.
pjuk
233
130
North London
I've heard about one pedal driving but cannot find it anywhere in the settings on my MX with 2019.36.2.4
I've only got standard/low for regen and a creep toggle button.
