One week old M3 and scratched the alloys...
KaraGUK
22
5
Hampshire
I could cry... My husband has managed to catch the edge of one of the alloys, basically the only part not covered by the aero. Does anyone know how much it would be to repair the damage?
Adopado
3,262
2,422
Scotland
There's very little visible on the edge, as you say. I would sand it flat and use touch-up brush ... you'll never see it unless it was really bad. Seems hardly worth a full wheel refurb but if it's going to play on your mind Google your local repair people ... there's loads ... and it's not really that expensive.
Reactions: KaraGUK
KaraGUK
22
5
Hampshire
Thanks, I have zero experience with alloy damage so didn't know doing something myself was possible. I will look into as keen not to pay for a full refurb especially if it happens again...
Adopado
3,262
2,422
Scotland
Ford "Dark Shadow Gray CX" is a perfect match I am told. It comes in a tiny nail varnish type container with its own brush. I bought some but haven't used it yet.
(Oh, BTW I also shed a tear when caused the first minor damage to my M3 ... it always happens with a new car.)
Glan gluaisne
2,782
2,688
UK
If a DIY repair doesn't look as if it will do the job, the mobile chip repair people can usually do a really professional job for less than the cost of taking the wheel in to one of the refurbishment places, I think. I had some minor scuffs done by one of these companies before I traded in my old car, and was very impressed with their work. The repair was completely invisible, even when I knew where to look. I know they do alloy wheel repairs, as I friend had a kurbed alloy done by the same chap that did my old car (and my wife's car).
Rooster6655
1,516
524
UK
My passenger side rear wheel seems to be the only one I have scratched and more than once as well! Going to try the paint recommended above.
VanillaAir_UK
7,153
4,675
Surrey, UK
Its going to happen again.
Basically there is zero protection offered by the tyre to stop the rim getting damaged. You can even lay the wheel flat on the ground and the rim will likely touch the ground.
Normally a tyre is more bulbous, so even if the tyre flexes when it hits a hard object, its going to hit first and likely deflect before rim is hit. This won't happen with a Tesla rim/tyre combination. The rim is right in the firing line so even gently rubbing against a curb that is taller than the tyre sidewall, the rim is going to get scraped.
Glan gluaisne
2,782
2,688
UK
Years ago the tyres on a car I owned had moulded-in rubber ridges that stuck out to act as rim protectors (or I assume that's what they were for). Seemed a really good idea, as the tyre acted as a buffer to prevent rim damage at low speeds. I've not seen tyres like this for years, which seems a shame, as they seemed a good idea.
Adopado
3,262
2,422
Scotland
Agreed. To me the tyres on the Tesla look a bit stretched for the width of the rim maybe an 8 inch rather than 8.5 inch rim (or 245 width tyre) would allow more chance of some sidewall sticking out beyond the rim. There's no doubt this could be improved.
Adopado
3,262
2,422
Scotland
Glan gluaisne
2,782
2,688
UK
No, not at all cheap for what they are! There seem to be a few similar products around, but I can't help thinking that there has to be a neater way to do this; the joint looks a bit unsightly.
I wonder if anyone makes a bond-on hard rubber "bumper" that could be fixed to the tyre sidewall just outside where the rim seats? Sort of an add-on that replicates the rubber bit that stuck out on those tyres I had years ago.
MacJester
84
24
Cranbrook
At least he managed a week. I’d done mine within an hour of taking delivery! It’s not easy to see where the nose is vs the curb sometimes.
alstoralset
Man from another place
Nov 23, 2018
106
273
Pacific Northwest
I did it about a month in. What a terrible feeling. Fortunately, after reading that it has happened to so many others, the Kübler-Ross cycle passed quickly.
I did some light sanding and used the same touch-up paint everybody else seems to use, and the repair was acceptable. Hasn't happened again since.
KaraGUK
22
5
Hampshire
He may take some comfort in knowing he is not alone! He has been driving for years and never done this before. We will have a go at the DIY fix and hope that it doesn't happen again too soon. Thanks as always for your input!
Puddles
728
844
Fresno, CA
Yeah welcome to the club. There is something about this car, it must be wider than it seems. I’m continually rashing the passenger side rims, front and back. I’m resigned to getting a set of rim guards when I need new tires.
I can’t take credit for this but I’m into retro :)
