One week storage
Discussion in 'Roadster 2008-2012' started by Mitrovic, Jul 25, 2014.
Tags:
  1. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    In the beginning it was said that the roadster should be stored in the storage mode. Then it was said, no storage mode, but plugged in.
    Now I have the impression as it is best to keep the battery not fully loaded.
    So, when I go for a trip of one week. how would you suggest should I leave the roadster?
    - Plugged in in storage mode?
    - Not pluged in but full, or not full?
    - Plugged in in normal mode?
  2. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    If it can be plugged in, it should be. The only time you have to worry is if you can't plug it in.
    We've gone away on three week trips. The car was "normal mode" charged when we left, and we switched to storage mode, but when we got back, it had only lost a few miles of rated range and hadn't even gone down to the 50% level, so I wouldn't hesitate to leave it unplugged for 3-4 weeks if necessary. But a plugged in Tesla is a happy Tesla :smile:.
  3. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    For just one week plugged in standard mode. If much longer than that consider storage mode but then might need to charge for hours when you get back.
  4. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    Storage mode will maintain the battery at a lower charge state than standard mode. Regardless, the car should be plugged in. I put mine in storage mode when I was gone for three weeks, but I don't know that I'd worry about it for one week.
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Storage mode is designed for months. So if your car is a garage queen and only gets driven once a year or you put the car up for winter. But if you are talking weeks not months just leave it plugged in on standard mode.
  6. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    Of course it should read one week storage.
    NO, my car is a daily driver, But I will leave it for one week at home.
    I thought there were reports that for the battery it is better if the car is not fully charged. People even stop charging before it reaches 100%. That is why I thought may be a Tesla can be happier unplugged?
  7. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I fixed the title.
    If you're just going for one week, leave it plugged in Standard mode.
    Battery degradation is slightly higher if at high state-of-charge and high temperature. However, one week at 90% is trivial, and all leaving it unplugged or in storage mode for a week would do is degrade the pack balance a little. (My Roadster was unplugged for four days recently, and "lost" 6 km of range as a result.)
  8. slcasner
    slcasner Active Member
    Sunnyvale, CA
    I believe the caution about always plugging in the car is stated just to avoid having cars left unplugged in storage for months where the battery can be depleted and damaged. The Storage mode keeps the level around 50% because that has been established as the best way to minimize deterioration when the battery is not being used. My car is my daily driver for those days when I drive, but I only plug it in to charge when the level gets down between 50-60% or when I know I need more the next day. Leaving the car unplugged for a week when starting from 80% or whatever would not concern me. YMMV.
  9. djp
    djp Model 3 Performance
    Toronto, Canada
    Storage mode maintains the SOC at about 20%. It takes about three months of vampire drain for the pack to drop that low if starting from a Standard charge. I wouldn't worry about Storage mode for one week - it'll make zero difference.
    Definitely plug in though. I always keep the car plugged in when I'm away on a trip, just in case I get stuck somewhere and can't make it home in a few months. :smile:
  10. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    For a week, plugged in with Standard mode is the way to go. As confirmed by many Tesla employees a couple years ago, and still today.
    If your car is in for service for a week at Tesla, they won't be keeping it plugged in.
  11. wycolo
    wycolo Active Member
    WA & WY
    When I go away I connect the (supplied) 120 volt cable to the Roadster because this is direct, not thru a charger thus more reliable. Besides, the MS is on the charger. No need to rush home with this scheme.
  12. dhrivnak
    NE Tennessee
    Not sure where you got that information but connecting from 110V or 220V is no differetn to the car. They both to through the charging circuitry as the battery is 400V DC and cannot be directly connected to 110V AC. If you were to do that sparks will fly.
  13. djp
    Toronto, Canada
    I think he means the 240V connection uses an EVSE (the UMC), but the 120V spare adapter is straight-through.
  14. wiztecy
    wiztecy Active Member
    Why let the Roadster sleep at 84% SOC for longer than a few days to keep topping off with like whip cream on a hot fudge sunday that's just sitting and not being used?
    I just took a 2 week trip up in Alaska, and I must say its beautiful. I left my Roadster at 140 std. mode ideal miles when I left, when I returned it was at 119 ideal miles. I let it sit in Storage Mode. Storage mode wakes once a day to tally the SOC and if it needs a charge it'll give it. I believe 20% SOC is the cutoff, Doug's the best on that one. Reason I leave it storage mode is that I don't want it at a higher SOC than what it needs to be just sitting. I target 50-60% which is where the pack wants to be idle. I live in Santa Cruz where luckily the ambient outdoor temp is 75 degrees F being close to the ocean. A temp the pack likes. I leave it in storage mode just in case something odd happens with a vampire drain rather than being unplugged. I could have left it unplugged but I feel better with the Roadster waking up daily to check itself if it gets low on electrons.
    I would not suggest keeping it on std. mode charge and don't know where that came from. Storage mode is just that, storage, no matter what the duration.
