Our solar roof was installed in March, 2020, but we did not get PTO until 7/20/2020, so we have now been fully operating for just over a year (and numbers below are mostly for 8/1/2020-7/31/2021 for convenience.) The system is about 8.19 kW (split 50/50 north/south) with a 7.6 kW Delta Solivia inverter, and we did install 2 PWs. Overall, everything has performed great. We produced almost 6% more electricity than the Tesla estimate, and the system operated without issue the entire time. We had about 25 backup events, though all appeared to be brief blips - no actual outages. We did, however, operate offline for about 3 days total to test the system.
Below are our actual numbers, and a comparison to various estimates.
The Tesla number comes from the contract, while the PVWatts number comes from using their website, and may be a slight overestimate based on not providing correct parameters. A closer estimate should be the numbers from SRECTrade. Because we have a system under 10 kW, Maryland allows us to receive SREC credits based on estimated production instead of actual results, and SRECTrade produces those estimates (and is also based on PVWatts.)
What is notable is that our system has matched or outperformed the PVWatts/SRECTrade numbers in the spring and early summer, and significantly underperformed for much of the fall and winter. While weather could be part of it, I also suspect that being in a fairly densely-built neighborhood, the effects of some trees and houses blocking the sun nearer the horizon are likely more pronounced at that time of year. Below are two charts illustrating the monthly performance (Tesla does not provide monthly numbers, so these were estimated based on the PVWatts numbers.)
Finally, with an east-coast system, it is interesting to look at the daily data to illustrate how variable it is compared to some other climates. While the annual cycle is clear, the variation from day to day can be significant. Overall, our best three days were all in June, with it being relatively cool in the second half of the month just as we hit the solstice:
Source | Annual Production (kWh) | Actual Compared to Estimate (%) |
Actual | 8342 | 0 |
Tesla | 7876 | 5.9 |
PVWatts | 8698 | -4.1 |
SRECTrade | 8501 | -1.9 |
- 6/17/21: 47.7 kWh
- 6/23/21: 47.6 kWh
- 6/16/21: 46.4 kWh
- 12/16/20: 0.7 kWh
- 2/18/21: 0.8 kWh
- 11/11/20: 1.1 kWh
