  • The TMC Podcast team will be live streaming a Tesla AI Day watch party today at 4:30PM PDT. Check out this podcast clip for more details. You will be able to watch the stream on YouTube.
Ontario - Charger Install / ESA Inspection
Had a 200a upgrade today, along with the installation of the Tesla Wall Charger.
I was out while the work was done - but it looks great (although for the $ it should do! )
Question - There is an ESA sticker on the outside of the tesla charger. With a serial number of 008.
Would that have been put on by the ESA inspector - or do they all have those stickers on them (i didn't open the box when I picked it up).
Also - the electrician didn't leave a copy of the ESA inspection report (so I can use it for the rebate). Would ESA mail those out - or should I chase the electrician to get a copy?
thanks
Previously I have similar stickers applied by the inspector -- I haven't done my HPWC inspection yet so can't be sure what they do for chargers. I believe whoever took out the permit will need to contact ESA to get the report (but they might also mail it). If you had an electrician do the work, they should be responsible for getting you the report.
thanks
The ESA inspection isn't done by the electrician. It could be that the inspection was waved by the ESA because the company has a good record, but you may want to call them and check it out.
You absolutely should be getting a certificate of inspection.
