Opel Ampera
Discussion in 'Electric Vehicles' started by dpeilow, Jan 27, 2009.
  1. dpeilow
    dpeilow Moderator
    Winchester, UK
    Europe's Volt - on show at Geneva...
    Opel Ampera: New Electric Car Features "Voltec" Technology
  2. dpeilow
    dpeilow Moderator
    Winchester, UK
  3. dpeilow
    dpeilow Moderator
    Winchester, UK
  4. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    I like the Vauxhall grill better ...
  5. Cobos
    Cobos S60 Owner since 2013 - sold, S85D owner since 2017
    Oslo, Norway
    Interesting because I think that photoshoped Vauxhall looks really ugly while I think the Volt actually looks very good on pictures. I couldn't stand the Volt concept car while the production model looks very nice. Depending on what happens to the Model S, I might actually end up with a Volt.
    Cobos
  6. vfx
    vfx Well-Known Member
    CA CA
  7. Cobos
    Oslo, Norway
    Hey ! Stop hitting that car with that stick. Yes I know it's an ugly stick but no need to go on hitting the car, you've obviously already done your work....
    Is all I've got to say about that :)
    Cobos
  8. doug
    doug Administrator / Head Moderator
    SF Bay Area
    I don't mind it's looks that much. Does look like it's got tribal war paint on, though.
    I think I prefer this interior color scheme to what we've seen so far for the Volt.
    Opel Ampera - a set on Flickr
  9. TEG
    TEG Teslafanatic
    Yes, the interior looks much better in black rather than white.
  10. dpeilow
    dpeilow Moderator
    Winchester, UK
    British-built electric car to rival Tesla S | ETA
    This 'electric car with 300 mile range' line that GM are touting and the journos are swallowing is ridiculous. I mean, if I stick my car in gear and turn the key, I get about 10 feet of electric motoring before the range extender cuts in and I go about 400 miles. Start comparing apples with apples...
  11. graham
    graham Active Member
    Aptos, California
    I am a bit confused by the "300 mile range" they tout as well.
    The press generally treat the series hybrids as if they were gas cars. You fully charge the car, you fully gas the car, you go 300 miles. Then you run to the gas station and refill the car to go another 300 miles, just like a regular ICE.
    But I was under the impression that during the "range extending" portion of the trip, the car is still using battery power because the engine is not powerful enough to recharge or maintain the battery at highway speeds. When you get to the 300 miles, you have no gas and no battery and you will be unable to go farther at highway speeds until you recharge the battery just like a regular EV.
    Do I have that wrong?
  12. Cobos
    Oslo, Norway
    I'm pretty sure the engine/generator on the Volt is powerfull enough to let you at least do highway cruising while the battery is "empty". An empty battery though still means you've got about 6kWh left for hard acceleration. But calling this is a 300miles EV is simply not true. Or at least bending the truth into a pretzel...
    Cobos
  13. graham
    Aptos, California
    Oh, I agree -- perhaps I didn't phrase it properly. When the Volt's battery gets "empty" after 40 miles of EV travel, it still has quite a bit of charge in it. However once the range extender kicks in, I do not believe the gas engine has enough power to maintain that charge at highway speeds. Therefore the volt gets "emptier" after 40 miles while traveling on gas alone, eating into its reserve power. Once you get to a certain point in time (probably the reported range of "300 miles") I believe the battery to be drained enough that you will not be able to go further at normal speeds without a recharge.
    I recognize when it says "empty" it isn't really empty. And there may be several definitions of empty. My point is that the press treats the Volt as if it is a gas car and supposedly has quite the advantage over a full BEV because when you are empty, you can just fill up at the next gas station and keep going. I do not believe that is actually true. At some point, you will not be able to just put more gas in and continue to go down the highway - you will have to recharge just like a regular BEV.
    If this is the case, the main advantage of a series hybrid like the Volt of fast fill ups at the pump might not be as big an advantage over a full BEV which already has a range of 300 miles like the Model S. (Well, other than that huge price difference)
  14. donauker
    donauker Member
    Where does this myth come from? It has been stated that the Volt will have a 53 kW generator. This is several times the capacity needed to keep the Volt moving at highway speed. You could drive the Volt as long as you wanted to without ever plugging it in.
  15. graham
    Aptos, California
    Ah! I stand corrected then. I hope this is true!
  16. dpeilow
    dpeilow Moderator
    Winchester, UK
    Ampera boost for UK | Auto Express News | News | Auto Express
    First time I have heard about diesel in the production version.
    That I can support.
  17. dpeilow
    dpeilow Moderator
    Winchester, UK
    From the comments in the above story:
  18. dpeilow
    dpeilow Moderator
    Winchester, UK
    #20 dpeilow, Feb 27, 2010
