TonyWilliams
I've asked the above poster for the board and will order the Silicon Labs dev board set up shortly. It comes with a fob and a receiver. With luck, I can use the receiver to determine the code then program that into the fob. I'll check DigiKey to see if they sell just the fobs (for those that want one).
The card is coming to you US Priority Mail. You're welcome to put three test leads in the annotated spots. Please use the correct colors, if you can, just to keep things easy to follow along. The antenna outputs U1 at R5 to loop around the card (U1 pins 3 and 4):
Blue - 3.3 VDC
Green - Ground
Orange - Proximity
http://www.silabs.com/Support%20Documents/TechnicalDocs/Si4010.pdf
U1:
U1 Programming Mode
