Notifications are controlled by the phone. Look under SETTINGS, NOTIFICATIONS. Scroll down to OVMS.I'm sure this has been asked before, so apologies but I can't find it.
At some point I changed a setting on OVMS to suppress annoying messages on my phone such as the driver's door is open. It would be useful to get alerts through again, so that I can see if there is an HVAC warning message.
Where is the setting for this? I have SMSIP enabled and I can't see anything else stopping them. Feature 14 is set to 1.
Carbits. I think it's feature (or parameter) 14. Set to 1 to get alerts. Set to 8 to disable alerts. There's probably more significance to those numbers.No it's not this. OVMS has priority on the phone already.
The messages aren't stored under messages in the OVMS menu either.
There is a car side setting somewhere which suppresses these messages.
I have the same issue which has started 2 weeks ago. There must be something wrong in the software. This has happened in november 2015 as well and was solved with an app update.No it's not this. OVMS has priority on the phone already.
Does anyone know the correct APN settings for T-mobile USA pay-as-you-go?
We are using:
APN: internet2.voicestream.com
Username: voicestream
Password: [none]
but doesn't seem to be working correctly.
@markwj any idea about my issue above. I'm still not seeing the messages I am after, I just get the charge done SMS messages despite requesting SMSIP and trying to get all messages.
I switched to h2o. Bought the sim for a buck or something on Amazon and loaded it up via h2owireless site. Aside from changing the phone number, I do not recall needing to make any other changes. Been working since last Fall.AT&T support for my OVMS stops in Dec. Who can I switch to that supports the OVMS?
