Here's my post about it, but see the other posts in that thread, too. Original idea from @ML Auto.Wow, good idea.... can you PM specs, diagram...... how you did it. Its been pretty hot up here in Sedona and that idea sounds great.
Q: I'd like to revert back to seeing amps on the dash display (as there is a 2nd speedo as part of the central radio)
BUT (probably my stupidity or memory of original settings) , In the app, when I change the feature 'digital speedo' for this setting from 1 back to 0 it doesn't go back from mph to amps.
Can anyone suggest a definitive method for OVMS v2 to change mph back to amps ?
Thanks again Steve. It took a while but we got it going. There is absolutely no way that I could have done this myself. I owe you big.Henry, I expect I can provide more assistance remotely. Contact sent.
Steve
After several code iterations with testing help from @rudholm and another tester, I believe this problem is fixed and the fix is now committed to the master branch so it will be in the next firmware release. Moving the slider on the charge connector icon to start charging when the car is asleep should successfully wake up the car and start charging whether the car was waiting for a scheduled start time or after charging was stopped by request or after a previous charge has finished.When the car is plugged in, but not charging, if I slide the "Slide to begin charging" thing on the icon of the charging connector on the Battery page in OVMS, it doesn't start charging, it just goes into the "Charging -- Prepare" state (according to the "stat" command) but never actually charges. The car won't even charge when its scheduled charging time comes around. The only way to get the car to charge after it is in this state is to close the charging port door and re-open it, that clears the condition and you can start charging normally (but not through OVMS).
Thanks for your work on this project. Next time you're in LA, your drinks are on me.After several code iterations with testing help from @rudholm and another tester, I believe this problem is fixed and the fix is now committed to the master branch so it will be in the next firmware release. Moving the slider on the charge connector icon to start charging when the car is asleep should successfully wake up the car and start charging whether the car was waiting for a scheduled start time or after charging was stopped by request or after a previous charge has finished.
I already owe Steve a good meal in Santa Barbara...Thanks for your work on this project. Next time you're in LA, your drinks are on me.
As a new owner gathering experience with the OVMS charge control, I'm assuming the daily top up algorithm is buried in the logic somewhere. Can anyone tell me if it is easily modified. I am pleased with how well it works but have to wonder if I should be concerned with the daily wear and tear on the hardware and contactor switching it imposes.
Vampire creep seems to amount to losses of 1% daily so I am curious to know if it's possible to modify the charge control to top up every other day or on a larger drop in state of charge.
Please say more specifically what report you observed. Are you talking about the notification sent when a charge begins giving an estimate of charge completion? Or the notification sent when charging ends? Or some other display of the charge energy?The kWh calculation done and reported by OVMS does not appear to be too accurate. Is there a configuration setting available to improve the accuracy of this reported value? For example a ten minute charge at 240V 12A reports anywhere between 1 and 20kWh
Yes...the message sent on start of charging gives a peculiar charged value which I don't understand and then the message on charge completion gives another value which seems to me should be about 0.5 kWh for a ten minute charge but displays a value many times that amount. It looks like the integration is fine for long charges but short ones maybe generate something more random??Please say more specifically what report you observed. Are you talking about the notification sent when a charge begins giving an estimate of charge completion? Or the notification sent when charging ends? Or some other display of the charge energy?
I have the same experience with the end of charging notification indicating a strange value for kWh when the amount is very low. For example, Last night the car charged for 3 minutes at a low rate (I hadn't driven it since the previous day). It started and stopped on its own as expected. The charge completion notification said 12 kWh. It should have been less than 0.5 kWh.Yes...the message sent on start of charging gives a peculiar charged value which I don't understand and then the message on charge completion gives another value which seems to me should be about 0.5 kWh for a ten minute charge but displays a value many times that amount. It looks like the integration is fine for long charges but short ones maybe generate something more random??
My other question relates to trying to get an idea of battery health remotely via a shell ovms query. The documentation mentions the BMS and v+t display is not supported but the command line interpreter provides a BMS query. Like I mentioned BMS alerts gives me a result that seems meaningful but BMS status says nothing is available so I'm a bit confused.
