  • We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
Open Vehicle Monitor System (OVMS) - Technical Discussion
jaanton
Roadster NA #1026
Jun 25, 2010
337
14
Oakland, CA
I got my new 3.3 Module with 3.3 modem and have yet to get the modem to work.
It all works with my home WiFi network with the modem turned off. But when I turn on the modem (I'm using Hologram BTW) in a couple minutes it crashes.
Looking in the logs, it seems that the ppp is coming up just briefly sometimes getting an ip address in the 10.x.x.x range, but then looses it. reporting UserInterrupt in the log. I'm attaching the screen shot of the crash indication.
I'm not used to reading the log files, it would sure be nice if a reboot message was put in the log so it's clear that a crash happened. Since that information is in the dashboard I would think that should be in the log as well.
I drove away from my home WiFI and tried it again in a different location which might get better cellular signal, but it crashed again turning on the modem via my cell phone connecting to the access point of the module.
I've tried a bunch of stuff, booting the eap release (seems to be older than the factory/stable release) and I tried my friends' ovms 3.3.001 build and that crashed also. I have some logs but I'm not going to post them because they have sensitive information. Sigh.
I could take my old 3.1 board, upgrade it's software and move the modem there, but I feel this is a software problem mostly. Even if I'm having dropped cellular connections, the module shouldn't crash.
I moved to the new 3.3 board from my 3.1 by backing up the state on my sd card, moving it to the new module and recovering that backup state. That worked well, but I'm a little uncertain if that might be my problem i.e. if there is some incompatibility between 3.1 backups and 3.3 recovery.
Anyone with similar problems?
ShawnA
1,204
1,007
Edwardsburg, MI
Hi @jaanton ,
I would try to "Flash from Web" even if the software
is the same...
You will need to run configuration again related to the modem.
That horrible long number from the new modem, ICCID, has to be in your configuration.
Maybe it was restored or maybe not...
Your SIM moving from one modem to another should not be a problem...
If you are still lost @markwj is the man to help you.
Good luck,
Shawn
drewski
717
423
SF Bay Area
Not having much success with the new modem either. See post above yours.
I put it in my old module and flashed 3.3.001 via web. My build # is the same as yours, but date is from November?
Need to look if there's anything useful in the logs.
jaanton
Roadster NA #1026
Jun 25, 2010
337
14
Oakland, CA
You are on the 'eap' thread/release cycle...
We're in a strange place where 'stable' is newer than 'eap'. I tried 'eap' and had the problem. Also, 'eap' didn't have a proper dashboard information via the web access. I would suggest downloading the stable release but I don't think that will solve the problem.
markwj
Asia Pacific
Moderator
Apr 10, 2011
4,679
1,378
Hong Kong
For those upgrading to the 4G modem, you *must* be running 3.3.001 firmware. Simplest way to get that is to set your release level to 'edge' and do a normal OTA update over wifi. You can also get it from this URL:
http://api.openvehicles.com/firmware/ota/v3.3/main/ovms3.bin
For the hardware, you should refer to the little table printed on the board that tells you which antenna goes where. It is different for the 3G and 4G modems.
If powering up on the bench, make sure you have a powered USB hub, or a good quality USB port that provides enough power. 4G is more power hungry than 3G.
If you still can't get it working, create a support ticket at www.openvehicles.com and include the 'module summary' output after the module has been plugged in for a few minutes. It is helpful if you can leave it plugged in, connected via wifi, so we can remotely connect to check.
Reactions: drewski
jaanton
Roadster NA #1026
Jun 25, 2010
337
14
Oakland, CA
Quite a bit of investigation has occurred and it seems that not having the GPS part of the cellular modem enabled is causing the crashes.
The Roadster OVMS uses GPS from the car instead of the OVMS cell modem.
If you enable the GPS from the cellular configuration that might fix the problem. It's working for me with no apparent ill effects.
You need the 3.3.001 firmware as Mark mentions.
I don't have a GPS antenna attached to my OVMS module, just enabling it got me work.ing.
Reactions: drewski
drewski
717
423
SF Bay Area
Same build idf so think we have the same build. Just moved from /eap to /stable.
My dashboard looks to be OK.
I'll try your GPS suggestion and then re-flash.
Curt
Roadster Signature #55
May 13, 2013
447
188
Rockville, MD
I'm a little confused.
When should I upgrade to v3.3.001? Before or after the Modem board swap?
I just switched my firmware setup to edge, downloaded what appeared to be 3.3.001, but on reboot I have two partitions with 3.2.018 installed.
slcasner
1,536
1,079
Sunnyvale, CA
Normally before the board swap.
Hard to say exactly what happened there. Maybe some missed step?
As @jaanton mentioned above, with 3.3.001 and the 4G modem you need to enable GPS, even though that would normally not be used with the Roadster, to avoid repeated crashing. 3.3.002 is coming soon.
Reactions: drewski and miimura
jaanton
Roadster NA #1026
Jun 25, 2010
337
14
Oakland, CA
Probably the easiest way to get 3.3.001 now for an older (v3.1 or v3.2 board) is to go to firmware/flash from web and change the word 'main' or 'eap' into 'edge'.
I just did that for my old 3.1 board via this uri:
api.openvehicles.com/firmware/ota/v3.1/edge/ovms3.bin
I understand that the 3.1 and 3.2 boards use the same firmware but probably good to do the right thing for your hardware.
FYI: I'm no longer using my v3.1 board with any vehicle. I bought the new v3.3 board and aside from this GPS bug I'm quite happy with it. The WiFi is more sensitive and I don't have to park as close to my home WiFi hub as I used to and the cellular signal is also stronger but that's hard to tell if it's due to so few 3G towers left.
If you don't know what hardware version you have maybe go to the status page and look for the version of your 'factory' software. My old board shows '3.1.006' which is pretty old now.
I also want to thank @markwj and all the OVMS developers for this project. I bought the early v1 hardware so I'm now on my third hardware.
drewski
717
423
SF Bay Area
Enabling GPS didn't work.
I also flashed the latest Edge release (3.3.001-285-g601f2a70/ota_0/edge (build idf v3.3.4-848-g1ff5e24b1 Feb 20 2022 00:04:30)) and same. Connects to Google Fi, but not to the server.
I've opened a ticket per mark's post.
jaanton
Roadster NA #1026
Jun 25, 2010
337
14
Oakland, CA
I have a Google Fi data-only sim and I've tried to get it to work. Sometimes it shows "Google Fi" as a provider. I set the APN to "h2g2" but it does not work. What web searching I've found is inconclusive. There is some mention of an APN of "h2g2-T" and "h2g2-t" and other stuff. Some people say you have to run a Google Fi app but some say not. It's a crazy system and Google is no help just search the web or just try it, it's free.
It would sure be great if Google Fi would work because their data cost is crazy low.
But it seems like they are clamping down on the data-only sims. Some recent posts I've seen say there used to be a limit of 9 data-only sims and that's been reduced to 4. They seem to be getting more restricted.
If anyone has gotten a Google Fi data sim to work please post how. It would be fantastic.
drewski
717
423
SF Bay Area
3.3.002 is up in eap
Google Fi shows, but just cycles through NetWait, NetStart, NetMode, NetLoss, NetDown
I've had a Google Fi data-only SIM card working in my OVMS since I installed it a few years ago. I just got a new 4G modem yesterday (Medlock has them in stock) but I haven't installed it yet. My APN is set to "h2g2"
Reactions: drewski
miimura
7,465
7,511
Los Altos, CA
I have a T-Mobile SIM that I just installed in my new 4G modem. T-Mobile insists that everything is good on their end, but the OVMS reports
Code:
cellular: mux-rx-line #3: +CREG: 1,3
Network Registration: DeniedRegistration
cellular: Mux-rx-line #3: +CCLK: "22/03/21,15:01:54-28"
cellular: mux-rx-line#3: +CSQ: 18,99
cellular: mux-rx-line#3: +COPS: 0,0,"T-Mobile",7
cellular: Network Provider is: T-Mobile
Anybody have suggestions for how to get it working?
slcasner
1,536
1,079
Sunnyvale, CA
[snip]
[snip]
I have been using the Hologram SIM that came with the OVMS long ago. When I upgraded to the 4G modem my OVMS came up and registered just fine. But then I installed a 4G modem for @Timothy who is also using the Hologram SIM and his gets the DeniedRegistration error. I posted about this to the ovmsdev list but received no response. This coming Friday I expect to get Timothy's OVMS so I can try some experiments of swapping modems or SIM cards or to see if operation in a different region makes a difference.
Reactions: drewski
miimura
7,465
7,511
Los Altos, CA
Thanks for the reply. I saw your message on the dev list but wasn't sure if it was related because of the different SIM type.
