slcasner
Is the OVMS server at tmc.openvehicles.com port 6867 down today? On the iPhone app the antenna icon is just blinking gray, and an attempt to manually connect with TCP to that port gets refused.
+1 .Is the OVMS server at tmc.openvehicles.com port 6867 down today? On the iPhone app the antenna icon is just blinking gray, and an attempt to manually connect with TCP to that port gets refused.
Same here and the IP address is not reachable.
Pinging tmc.openvehicles.com [54.243.136.230] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 54.243.136.230:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
I think the green wire is your problem. It should be in the connector with the green/white wire. The green goes to the OVMS board.
There is a slide switch on the circuit board. Position the switch away from the LED's for GPRS, towards the LED's for SMS only.Well my v2 module showed up tonight and I'm having no luck getting it to work with my H2O sim card. I can get the module up and running to the point where I can SMS back and forth with it to set command and make queries, but I can't get GPRS to fire up no matter what I do. From what I can tell, I should be able to issue the following command and everything should start working:
GPRS att.mvno - -
But the module will never connect to GPRS after this point. Anybody have any tips, or should I just toss the H2O sim and try out another vendor? Argh....
Has work begun to decipher Model S's systems?
