Opening Falcon Wing Door without fob
Sm7400
12
4
Canada
Each day my wife walks up to the car and the front door opens but the falcon wing door will not open unless she uses the control panel in the car or the fob. She wants to be able to open the falcon wing door by pressing the door handle. We’ve played with settings and I’ve searched online and everything that shows us is related to manually opening the falcon wing door, not how to use the outside handle. The outside handle only works once the she has already opened the doors at least once some other way. Is there anyway to just unlock all the doors with either the fob or just so you can walk up to it and press any door to open based on having the fob on you (like every other car on the market)?
MikingCO
2021 MX LR+
Jun 22, 2016
138
133
Dallas, TX
I can walk up to my X and manually open a falcon wing door without opening any other doors or using the console. If you’re not able to you might want to chat service.
n.one.one
649
591
Metro Atlanta, GA, USA
You can set your preference as shown in the manual. I just ran a test and when the setting is 'on' the FWD's will not open. When you turn the setting 'off' the FWD's will open with a push on the outside handle.
Ruffles
309
379
Snohomish WA
The outside handles on my X were always a bit stiff. I couldn't just push right in the middle of the handle unless I pushed really hard. The square end didn't seem to budge at all. The best solution I found was to just push the pointy end. Could this be your wife's problem?
