Wonder if they are using some cool Lithium-Ion 12V battery (Probably not)
After looking at the latest skateboard deck they had on our showroom floor, and reviewing the test drive cars, can we even say the 12V system is separate from the main battery pack? I saw no evidence of a "separate" 12v battery anywhere... not that doesn't exist. Nor did I ask about it, but it just seemed that the whole car was so thoroughly built around a clean simple system - the main batt pack. ???
So perhaps it's just a matter of plugging the car in to get live juice?
There should always be a backup solution.
The skateboard also didn't contain the chargers... they are under the second-row seats. I bet the 12V system is somewhere similar, higher up in the body.After looking at the latest skateboard deck they had on our showroom floor, and reviewing the test drive cars, can we even say the 12V system is separate from the main battery pack? I saw no evidence of a "separate" 12v battery anywhere... not that doesn't exist. Nor did I ask about it, but it just seemed that the whole car was so thoroughly built around a clean simple system - the main batt pack. ???
There's a picture of the 12V somewhere on this forum. Unless I dreamed it up. Surrounding commentary spoke about the large number of cables coming out of it.
@Tommy - Can you update your post to include a link to the original post? I didn't have much luck finding it.
... like "What if we hit an iceberg that rips through more than 3 or 4 watertight compartments?"
That would be very, very unlikely to happen, wouldn't it? <snicker>
Good enough. But since you asked...@ brianman, I added Doug's flickr link. The photos are page 151 of the Nissan Leaf thread. Can you give me a primer on how to link posts within this forum to one's own post. I got an Apple but that doesn't mean I am smart.
... that the >> button shows up only if you provide a post number in your quote tag.God said:Let there be light
The 12V aux batteries in EVs have a long history of causing trouble.
Yes, my Corvette had a physical key to let you open the trunk. You could then crawl in and hit the manual release on the door. Model S will need something like this.True. A backup physical key which allows you access to the frunk for example would be handy. From there you could then open the door with a physical cable or something.
Jimmy bar won't work as the lock/unlock mechanism is in the car, not the door. My Corvette and Roadster are like this. Great theft deterrent but sucks if you lock your keys in the car.There's gotta be some mechanism to get in if there's a failure of the 12V system--it doesn't necessarily need to be a complete battery failure causing the problem, but it's magical thinking to believe that this won't happen once in a while. Unless there's some external access to the 12V one would be reduced to using a jimmy bar just to get into the car.
Given Tesla has said their sensors should be sensitive enough to tell which of two keys are in the driver's seat, I'd think Tesla could detect if the key was in the car and not let you lock it if that was the case. That'd be a nice feature.Jimmy bar won't work as the lock/unlock mechanism is in the car, not the door. My Corvette and Roadster are like this. Great theft deterrent but sucks if you lock your keys in the car.
Yeah, I was thinking about other cars. My Corvette would honk the horn if you shut the door and the key fob was still in the car so the tech is there.Given Tesla has said their sensors should be sensitive enough to tell which of two keys are in the driver's seat, I'd think Tesla could detect if the key was in the car and not let you lock it if that was the case. That'd be a nice feature.
