Opinion on wheels and tires setup
Hi guys. My Y LR need a new set of tires. I was thinking of changing the wheels:
Wheels
ENKEI PERFORMANCE
PHOENIX
  • 18x8
  • Finish: Gloss Black Painted
  • Offset: +45mm (same as stock just smaller wheels. less than 23lbs per corner.
Tires
QUATRAC PRO - SIZE: 255/55R18​
I know overall diameter will increased 1". other than that I think it will not rub.
Is anyone running this setup?
Tirerack says it will work. I'm surprised it's rated for SUV weight, but 23lb wheel would be great! I just dumped my 21" Ubers for 19" Stance SF03s at 24lb, and I can definitely feel a difference in acceleration, efficiency, and ride quality.
Reactions: Ezmendriz
Humm. I cannot confirm the wheel weight. In Tire rack it says 22lbs but in other sites they said 29. Huge difference. It only makes sense for me if I can reduce wheel weight. ENKEI site itself does not state a weight for this wheel. Does anyone knows?
Got excited and put the TSportline 18" with Michelin Pilot sports in the card plus the accessories. I dunno $3600 just seems to be a lot for a downgrade. The tires are almost double what tire rack is charging too. Ah well, Ill hold off I guess.
