Note: This feature currently requires accessing the site using the built-in Safari browser.
Looking for options for installing 6 electric car charging stations in a building parking lot as part of a larger project I'm working on...
what are the best most prominent options? chargpoint, etc?
Volta is in IL too.........
You might look into Volta here: Volta Charging | Home
Volta is only in California and Arizona now, but has plans to expand. Not sure if Florida is on their horizon or not. But these stations are free, paid for by advertisers.
Good luck!
thanks, I doubt we would want to charge $ for it... they are already paying for parking to get in the lot, should support all cars....
Others are more knowledgeable than I regarding Leafs, Volts, Prii, etc. All Teslas can charge at 40A. I haven't bothered to read about the X, but there is a rumor circulating (maybe confirmed by now?) that the X will be able to charge at 60A. Some of us S owners have dual chargers and can charge at 80A. I don't know what the maximum amperage that other makes can utilize, or if they can dial down an 80A charger to 30A.
It is the general rule that EVSE in public locations only utilize 30A charging plugs, since all makes and models can use them. But you may wish to have one unit that has 40+ amps with the others at 30, or some other combination.
There are several third-party companies out there (ChargPoint has been mentioned.) There is also EVgo, Sema, and a few others. They all install their proprietary charging stations.
Good luck!
If you are not going to charge and want generic J1772's, Clipper Creek has some very nice choices. The ClipperCreek Dual HCS-60 with Pedestal is very cost effective with 2 J1772's on a pedestal, each putting out 48 Amps. They also have 40, 32, and 24 Amp versions at lower prices.
One thing to be careful of is to check on how the parking lot is billed for electricity. If you are on a commercial rate plan with "Demand Charges," then the increase in cost for peak kW demanded could be quite a shock. See Demand Charges — The Hidden Cost (and dirty secret) of EV Charging for Businesses for some discussion. If "Demand Charges" are an issue, that probably pushes you to the lower powered (fewer Amps) J1772's.
Good luck on your noble mission.
What's the nature of the parking? Time can be relevant to demand charges.
