Charging note: I'm planning on using the L2 EVSE in my garage that I used for my Volt. It's a GE Wattstation. At this point, I'm very happy I went with the GE Wattstation and not one of the cheaper L2 units that were available at the time, as the GE Wattstation will do 32 amps, whereas many of the others at the time would only do 16 amps. In my opinion, 16 amps would be too slow, but 32 amps is sufficient.
I also got the plug in version rather than the hardwired version, but unfortunately, it's a 6-50 plug which Tesla doesn't support anymore. Otherwise, I would have had the option of just plugging directly into the wall, though I think I probably would have still used the L2 EVSE because it doesn't require dragging out the UMC.
So I definitely need to make sure the car has the J1772 adapter with it. In fact, I'd like to get a 2nd J1772 adapter, so I can keep one with my garage EVSE, and keep one in the car.
I tested the EVSE on an extended test drive of a Model S late last year. It recharges about 21 miles of range per hour. The car has dual chargers and thus is capable of quite a bit more, but 21 is enough to hold me over for awhile. The car by itself will tap us out for awhile, so any thoughts of a HPWC will need to wait awhile.
