Just wondering if you calculated the ambient temperature, the underground temperature and your car's tank's temperature when filling up with gas?
Um, OK I'll bite. So what does that have anything to do with figuring out how much it cost me to drive a mile? In an ICE car - it's simple, I drive 300 miles, put in 10 gallons @ $3.00/gallon or whatever, and it cost me $0.10 per mile. Done.
Not so easy in an EV when you charge at home, and there's other things pulling electricity at the same time you're charging so you can't just look at the meter. Early Tesla's reported only an 80% efficiency recharging. That's a pretty big number to ignore, so I was wondering what mine was. Plus there's vampire drain, about 3 miles per night in my car, and about 15 miles per day lost during the summer from cabin overheat (yes I can turn that off) when parked outside. All told, using 90% charging efficiency from
@Tam's posts above, and my actual usage was 6,400 kWh over my first year (17,500 miles), when my car says it only used 5,100 kWh. Big deal? No, as that still comes out to only $.03 per mile - equivalent to getting 87 mpg using local regular gas prices here and 110 using premium (a fairer comparison given no 4 second 0-60 ICE car uses regular).
For fun, I then compared it to the Audi S7 I was also considering. Saving $2500/yr just in fuel! And that's without factoring in free supercharging or charging at work (both available, but I rarely use).
@Tam, thanks for sharing your data. 90% seems a fair number to use.
