Thanks for all the good info. I'm driving it about 2 hours from tesla to my house so that should be plenty of AP time. Also really looking forward to the garage fit and how he car seats sit in the back (got a toddler and infant). Also would like to try out the summon feature for garage parking. For some reason I'm super concerned about how it will fit in my garage. Right now I have a Prius and highlander parked in there. Will get rid of the Prius when we get the tesla.
It's not offered to all and sometimes they will tell you no if you ask. YMMV..I didn't even realize an overnight test drive was an option... will keep that in mind potentially for my next Tesla
We want to keep the highlander due to it having the third row that can fit adults comfortably at least for short drives.The model S can easily replace your Highlander. I'd keep the Prius just to reduce footprint.
Will I be able to use the app on a car I don't own and only will be driving for a couple days?When you are using summon, it will be quirky if you have tight clearance on either side with the garage opening. First of all, dowload the app to your phone. If you just try to use summon from the column stalk to garage it, it may stop part way in and refuse yo go any further. With the app, you can eyeball the clearance amd resend the command if there is sufficient clearance. The summon command is VERY cautious now and I suppose is gathering data.
I use the summon to park mine every night in the garage. It does a better job of centering it than I can from inside the car and eyeballing it from outside the car gives me sufficient confidence to repeat the forward command. I am sure it will be better with time and software updates soon.
Not typically.
I asked and was told no. I went & did a test drive for about an hour with the Owner Advisor with me. I placed my order that day, knowing that I could cancel within a week & get a refund. A couple of days later I talked to my Owner Advisor & told her that I was really thinking about canceling my order and I asked if I could have an overnight test drive. At that point she that it would not be an issue & made arrangements for me to come pick up the car. I drove the car about 85 miles in just under 24 hours & it cemented my decision to buy a Model S! I drove one freeway curve that I drive multiple times a week to test out autopilot since I expected it to be a tricky curve for AP. The first time with the OA with me the car struggled with that curve. I was then given the same 70D for my overnight test drive & I drove that stretch of freeway two more times. The subsequent times the car was perfect. I could see how quickly AP learned on that stretch & others that were tricky for it. I can't wait to get my car!!It's not offered to all and sometimes they will tell you no if you ask. YMMV..
I really missed this during my overnight test drive. I use the app a ton with my current EV & really hated having to get into a hot car that was parked in the sun with no app access on the Model S!Will I be able to use the app on a car I don't own and only will be driving for a couple days?
