TBC tries to minimize the costs, but not agressively, so mostly discharging during peak and rarely during other times. The behavior is very dependent on the utility pricing and the built-in price numbers usually cause more discharge than is ideal as the system doesn't understand NEM rules, if you are a net exporter vs exporter and NBCs. So I use different numbers to get the behaviour that I want which is discharge to house load during peak with solar being exported to my reserve level (max credits), with solar going to the house first in the morning with excessive to the Powerwall for recharge (min NBCs).
On October 21, I switched my settings from Self-Powered to Time-Based Control. So just looking at the last 3 weeks of data, this week still with 2 more days left I get the following table:
- Oct 10 -16
- Solar Generated: 294.8kWh
- Home Usage: 156.6kWh
- PowerWall Discharge: 72.9kWh
- Net Grid Use: -125.5kWh
- Oct 17 - 23
- Solar Generated: 345.7kWh
- Home Usage: 150.8kWh
- PowerWall Discharge: 62.8kWh
- Net Grid Use: -184.6kWh
- Oct 24- 30 (Note this week is still missing 2 days of data 29th and 30th)
- Solar Generated: 253.6kWh
- Home Usage: 166.8kWh
- PowerWall Discharge: 28.4kWh
- Net Grid Use: -81.7kWh
In the limited data that I have, it seems as though Self-Powered mode seems to provide a better Net Grid Use result of exporting into mid to low 100kWh/week where the first full week of Time-Based Control (Oct 24 - 30) will seem to fall shy on the Net Grid Use export results. Time-Based Control drains my batteries down to around only 75-80% since its only discharging from 3:00 PM - Midnight, where Self-Powered will have my batteries down to around 65-70% by the time solar starts charging them the next day.
I guess I can do something like 1 month Time-Based Control and another month Self-Powered to get better data to compare against, but what do you take away from this data? Is Time-Based Control really better than Self-Powered for our use case?
My take away from this is that Time-Based Control will keep ~10% advantage on battery charge but you'll be pulling from the grid generating NBC and you'll end up with lower net grid export in comparison to Self-Powered mode where you sacrifice having 10% less battery reserve by the time solar starts charging but you'll never generate a NBC and seem to have higher net grid export.
