pd_australia
Your cable connects/ exposes can3 from the extension port (the 26 pin connector) to the OBD2 connector. The issue is, as @gregd points out, that can3 is also connected on the other side, from the 9pin connector on the OVMS to the car. So you will need to disconnect can3 on the car side of the OVMS so that the HUD communication doesn't reach the car.
I am attaching the relevant pin connection diagram for the 9 pin connector (from the OVMS v3 Developer Guide, see also post #9 from @markwj above) Note that the numbering starts with 0 in this chart, while the OVMS commands start with one, so can3 will be labeled "can2" in these charts.
So you will need to grab the cable that connects the OVMS to the Roadster and either cut the wires on pins 6 and 8 on the 9-pin connector, or remove/cut pins 2 and 7 on the roadster-end of the cable (the big rectangular connector).
I ended up rewiring the cable from the OVMS to the HUD to use can2 so that can3 would be available for future ESS related functionality in OVMS - therefor I had to disconnect the pins labeled "can1" in the charts.
Let me know if you need a photo of the cable - I can pull it out and grab a photo if helpful.
Thanks @Peter.h. I think i'd prefer to do the same and rewire the cable from OVSM to HUD, rather than missing with the other side .
Could I rewire the DA26 Connector and maybe get a male and female, and rewire CAN3 to CAN2? (In diagram below probably CAN2 to CAN1) and not connect the other two CAN busses?
OVMS Diag Port < ==== > DA26 Connector Male+Female (Rewiring CAN3 to CAN2 and disabling others) < ==== > OVMSv3 HUD to OBDII cable < === > HUD
