I'm having the same issue
@drewski had with constant timeouts when attempting to perform an OTA update to v.3.2.008 via WiFi (v.3.1.006 factory build on the one I just picked up... thx
@shrink). Is it normal for the system to bump you off the OVMS access point and attempt to connect to the user's home 2G WiFi access point during this process? If not, that's the issue I seem to be having. Perhaps I don't need the latest/greatest right now but I'd like to know I can take advantage of any updates in the future so I need to get this sorted out.
I've attempted to disable the modem as
@markwj suggested earlier in
this post but to no avail. Perhaps I'm not disabling the correct config setting?
Also, for some reason "Access point + Client" was selected as the Wifi mode in the Auto start configuration options. I went ahead and switched that to "Access point" only per the
installation instructions but I'm still not getting any love. Additionally, the instructions mention the following:
"If you have configured this combination manually, the Wifi network will not start automatically. You need to log in using a USB terminal and either do a factory reset (see Module Factory Reset) or (better) issue enable to enter secure mode, then issue config set auto wifi.mode ap and reboot."
So I attempted a factory reset in the Shell terminal but when I try to execute the "module factory reset" command and acknowledge by typing "y", I get an "Unrecognised command" response. BTW, the .bin file I'm attempting to access here downloads swimmingly in seconds via a standard web connection but will not update via the OVMS Firmware page
here. I could try the SIM card but I don't have an easy way to write to one so I'm leaving that as a last resort.
Please tell me this thing isn't bricked...
*UPDATE*
I'm now getting the following when attempting to Flash from web on the Firmware setup & update page:
"No internet access.
"The module is running in wifi AP mode without modem, so flashing from a public server is currently not possible.
"You can still flash from an AP network local IP address (192.168.4.x)."
FWIW, I'm connected via the OVMS access point and my WiFi client network should still be correct per the initial set up.
