P.E.M. Temperature at which Power Limit comes on?
Discussion in 'Roadster' started by sethr, Apr 21, 2016.
Tags:
  1. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    Hi all - does anyone know what P.E.M. temperature initiates power limiting? The last couple of days power limiting has come on rather easily (moderate driving in mild (70 degrees) weather). When I get home, with the power limit light still illuminated, the VDS shows a temp. of only 37 degrees C. I seem to remember the limit was 60 - something degrees? Also, the fans do not seem as loud as usual, but that may be my imagination. Anyone have any input? TIA!
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Something sounds wrong as it only happened to me once when it was just over 100 outside.
  3. Stefan T
    Stefan T Member
    Sweden
    The Power limit comes apprx 60C in the pem
  4. sethr
    Fairfax, VA
    It turns out (according to Tesla), that the temperature shown is actually an average of three temperatures, one for each section of the PEM, (and one was above 60, setting off the power limiting). I go in for my annual on Monday, two weeks earlier than I'd scheduled. Interesting tidbit of info.
  5. NigelM
    NigelM Recovering Member
    Northern Virginia
    If you go into the service FW settings you can set your VDS to show actual temps of the three different components.
  6. wiztecy
    wiztecy Active Member
    Are you sure you're not confusing the 3 individual components with 3 temperature points on a single component? In your case you're talking about the motor, PEM, and battery correct? Sethr is talking about 3 unique temp pickup locations on the PEM itself that then is averaged together to come up with the finalized PEM temp. I don't believe there's anywhere in diags that displays those 3 points, at least on the 1.5 and I've poked around on the 2.x's as well.
  7. NigelM
    Northern Virginia
    Correct. I'm thinking it's at least much more accurate that the colored bars.
