P100D, 760HP and Performance Tests
Discussion in 'Model S' started by fiksegts, Sep 15, 2016.
Tags:
  1. fiksegts
    fiksegts Active Member
    Miami
    • Like x 16
    • Informative x 3
  2. tonglaji
    tonglaji Member
    cary, nc
    A couple of interesting observations from the video:
    1) The center console comes with rear cup holder and rear USB ports, hope it is not a P100D special
    2) At the end of video, the guy sat in a car with pano roof, and talked about "this car", while it was clearly stated earlier in the video that "this car" does not have pano roof.
  3. msnow
    msnow Active Member
    SoCal
    It beat the EPA rated range by 2 miles.
  4. techmaven
    techmaven Active Member
  5. fiksegts
    Miami
    still had 10 minutes to charge, will probably indicate 320...
  6. J1mbo
    J1mbo Active Member
    UK
    Could be the new Premium seats as well.
    @fiksegts DId you check the autopilot cam? Still only 1?
  7. NDR
    NDR Member
    South Florida
    Single ap cam
  8. Jeffgtx
    Jeffgtx Member
    West coast
    Thanks for sharing. Great upgrade commercial for those of us waiting!
  9. msnow
    msnow Active Member
    SoCal
    • Funny x 13
    • Like x 4
  10. Shateam
    Shateam Member
    NJ
    Does this put the AP 2.0 rumors to bed? I can't imagine Tesla delivering a $140K car that would be "obsolete" in a couple of months??
  11. ShotgunF15E
    ShotgunF15E Member
    San Diego, CA
    I can...
    • Funny x 14
    • Like x 5
  12. TIppy
    TIppy Active Member
    Tampa, FL
    #12 TIppy, Sep 15, 2016
    Might be time to send those scales in for service. On his car the left front was 160 lbs heavier than the right front. On this car there is a 475 lb difference. Or if the ground is that far out of level, the weights probably aren't accurate.
    The front to rear weight distribution is backwards, too.
  13. St Charles
    St Charles Member
    Virginia
    @fiksegts On your video, the P100D showed a power warning during the vbox test. Any ideas what the car was complaining about?
  14. Btr_ftw
    Btr_ftw Court Jester
    Mass
    my observations
    looks like the car lost 9 miles of range after the launch
    crazy how the car traps 6mph higher than your old P90 DL
    curious as to if there is a difference between the P85D, P90DL drive unit and the P100D drive unit. I want to know how much more power these motors can handle before they are at the breaking point.
  15. eclipxe
    eclipxe Member
    I'm hearing no AP 2.0 hardware this year. Some things have...changed.
  16. fiksegts
    Miami
    I added a graph of the P100DL vs P90DL v3 (the TRC car)
    • Informative x 7
  17. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    @fiksegts Awesome video! Can't wait to see more.
    Looks like the P100DL hits 100 mph as the Bolt is just hitting 60 (6.5 seconds)
    Also thanks for showing us the 317+ rated range at nearly 100%.
  18. TIppy
    TIppy Active Member
    Tampa, FL
    #18 TIppy, Sep 15, 2016
    I wondered why the 1/4 time wasn't better. Not much difference once you get 95 mph. Power starts dropping off at about 75 mph. Plus the 90 has more power between 15 and 35 mph
  19. jlewisthe3rd
    jlewisthe3rd Member
    Philadelphia, PA
    Tesla batteries are "overcharged" when new so they all show more range than specified.
    They have been doing that every few months since introduction of Dual Motors....can anyone say P85D w/ INSANE mode? Pre-AP cars had YEARS of being relevant, but now you only get a couple of months to be king of the mountain, innovation is the only thing that matters to TM.
    Yep energy consumption is through the roof but rightfully so if they want to hit those numbers.
    I've heard similar, and if true its in their best interest to NOT release AP 2.0 this year less jeopardize their guidance with people "waiting for AP 2.0". IMO they should release AP2.0 during or after Model 3 part 2 reveal.
  20. fiksegts
    Miami
    It's quite hard to line up the data points between runs due to the sampling rate...
