My lord how may times do I have to say it. I was simply giving an example of a compact 2 speed that can easily take the power because you claim it can't be done which is clearly wrong. And remember electric motors has a much higher rmp range, as everyone likes to point out, so a powerglide would be nowhere near as bad on the road as a ICE car. Actually unless you needed the high speed power you could leave it in first gear all the time. There is not shifting linkage, you are just disengaging one clutch and engaging the other. I don't think you understand how im saying it could be made. After the clutches besides the gears and shafts there is no moving parts, no synchronizer, no sleeves, no hubs, no shift forks, just 2 gears permanently fixed to two separate shafts and you just select which to turn with the clutch. Even when your in second gear, first gear is still turning, the power is just not going through that route. Vise versa for first gear.
Think this (I know is doesn't look like this, its a shaft in a shaft from the clutches but its easy to visualize) with only first and second gear and both gears fixed to the shaft, just pick which clutch to close, Very simple. The gear not being used isn't disconnected from the shaft, just the clutch is not engaged. The lubricating of the gears as a weak point is ill relevant because you have to do that on a fixed ratio single speed as well. Then like I said the main only thing to go wrong is the clutches, and as I said they can be made to last a long time.
Have you not caught on yet that I am not saying they need to put one in the model s right? Its a luxury sedan, not a sport one. So yes, it would be dumb and not cost effective to redesign the model s for a second gear when its not a performance sedan. Im saying if they(or any manufacture) were going to build a true sports sedan or sports/super car, its needs a second gear and this is how it can be done and I believe this is how rimac does it.
