Agree for the 85. The taper is very rigid and pre programmed. For the 100 it appears that it is following different taper curves depending on battery thermals. Tesla could allow more flexibility in the 85s which could result in fast charge times depending on conditions, but to date they have not done this.
When I tracked battery temp last weekend, I noticed that I gets quite hot (like 45 C) before the compressor fires up to full tilt. As soon as the rates dropped below 100 kW, the compressor stepped down rapidly. If the compressor held constant, I'm confident that thermals could be kept in check and the 85 could hold 100 kW into the 50-60% range. The compressor could also kick in sooner and not wait until the battery reaches 45 C.
