P100D to get more power
Discussion in 'Model S' started by fiksegts, Nov 4, 2016.
Tags:
  1. fiksegts
    fiksegts Active Member
    Miami
    As per tweet from Elon
  2. Green Pete
    Green Pete Member
    Ann Arbor, MI
    #3 Green Pete, Nov 4, 2016
    Someone with some background in battery tech want to wager on the physical possibility of the p100d battery capacity being more akin to p200d? I know nothing and I don't actually expect it to be double but even if it's 50% over what we assume that would be nuts.
    I know those numbers are pure fantasy but anyone want to give a more reasonable guess what the potential of the p100 Easter egg battery capacity could be if the Easter egg is indeed range?
  3. nwdiver
    nwdiver Active Member
    United States
    More kW... probably not more kWh...
  4. Green Pete
    Green Pete Member
    Ann Arbor, MI
    Right. But how many more? I mean. Imagine if the model 3 being more lightweight than an S turns out to have 30% more range than the S with a comparable battery and then turns out that the p100 battery actually has 200kw giving the model 3 an obscene 800 mile range
  5. shokunin
    shokunin P85 & M3
    Irvine, CA
    In addition to more, the car needs to sustain power longer and hopefully run in the 10.6's. We've moved from trying to break 11 secs down to getting in to 10.6's.
  6. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    Correct me if I'm wrong, but it seems like the phrase "Easter Egg" has been mostly used for fun elements hidden away within the touch and instrument screens of the car... and less about physical things.
  7. Green Pete
    Green Pete Member
    Ann Arbor, MI
    You are right. But the left handed comment coupled with the hush hush nature of the 2170 true battery density points to it being potentially something more this time.
  8. shokunin
    shokunin P85 & M3
    Irvine, CA
    According to Elon or maybe it was JB, the 100KW packs are still using the 18650 cells and not the 2170's. The next jump in battery capacity will come from a new pack design with the 2170's.
  9. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    Repost from my thread: I think this time it will unleash more performance. EM again on Twitter, credit Electrek for the movie reference catch: (current P100DL has been using left hand the whole time!)
  10. sammyfan711
    sammyfan711 Member
    Downers Grove, IL
    I'm thinking 2.3 0-60 for the S and 2.7 for the X...
    nothing too crazy
  11. eyespii
    eyespii Member
    Orange County, CA
    Kw = power = acceleration
    kWh = battery capacity = range
  12. nwdiver
    United States
    Dunno... my point was that no matter how many more kW it'll still be a P100D (100kWh) ;)
    They did up the kW of the P85 ~5% or so... IIRC it's currently ~560kW... so maybe an even 600kW?
  13. sandpiper
    sandpiper Active Member
    Ontario, Canada
    You're be facetious I assume. :) That fits any definition of crazy that I know of.
